icoLagrangianFoam OF1.6 myNewParticleSolver
Like Tree1Likes
Old   May 12, 2020, 10:08
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
@Bernhard, I hope you are doing well in Leoben.
@Simon, there also exists a solver named icoUncoupledKinematicParcelFoam (https://cfd.direct/openfoam/user-gui.../#x13-960003.5)
SimonStar likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   May 12, 2020, 10:50
SimonStar's Avatar
Simon
SimonStar is on a distinguished road
Hello everyone,
thanks a lot for replying, Tobi.
In my case I have a SteadyState simulation (with SimpleFoam) and I only want to calculate the particles with the transient model.
Is it a valid method to first do the simulation with SimpleFoam and than use the icoUncoupledKinematicParcelFoam with the U-Field from SimpleFoam?
If yes, is there any further help available that you know?
Thank you
Simon
SimonStar is offline   Reply With Quote
Old   May 12, 2020, 17:57
Tobi's Avatar
Tobias Holzmann
Hi, the solver mentioned above needs a pre-calculated U-Field. So your approach is fine and common practise. However, here, you do not have a back coupling to the velocity field.
Keep foaming,
Tobias Holzmann
Old   June 2, 2020, 03:18
SimonStar's Avatar
Simon
Hello again.
Thank you for the answers that is really helping me understanding.
I wold like to get a little more specific because after trying this for a couple of time there was no success.
My plan is to use the hopper-tutorial from the icoUncoupledKinematicParcelFoam-Solver as a starting point.
The tutorial has 2 Folders with two (part-)Simulations (hopperInitalState and hopperEmptying). For me it seems like non of them is calculating a velocity field because both are using the same Solver and the Particles are just affected by gravity.
BUT in the Allrun stands the fields are copied with 'mapFields'. What is exactly done in the initial state??
1. Can it be that I have tu run the solvers three times? First for Example the SimpleFoam for the U-Field and than (like in the Tutorial) two times the icoUncoupledKinematicParcelFoam-Solver.
2. Do I have to change the U-File in only one or both of the Tutorial Cases? And how can this be done? If I am just replacing the file the error occures.
Thank you for any help
Simon.
Parallel using icoLagrangianFoam flying OpenFOAM Running, Solving & CFD 37 March 25, 2011 06:02
Arbitrary crack propagation using OF1.6 gilav OpenFOAM Programming & Development 1 May 22, 2010 07:52
compressibleInterDyMFoam on OF1.6 lucadauria OpenFOAM Running, Solving & CFD 2 February 24, 2010 21:18
rhoSimpleFoam OF1.6 sheintz OpenFOAM 4 September 3, 2009 08:41
icoLagrangianFoam parallelizatrion problem shchepan OpenFOAM Running, Solving & CFD 3 July 28, 2009 09:48
