Pressure calculation problem
Old   August 15, 2010, 09:03
Default Pressure calculation problem
Maolong LIU
maolongliu is on a distinguished road
Hi, before I post about the convergence problem using simplFoam.
http://www.cfd-online.com/Forums/ope...n-problem.html
Now I guess I found the reason that induce the convergence problem.
Here is my situation.
I was calculating water flowing in two parallel pipe which are connected i with a 1mm gap n the middle as shown in the attached figure. The problem is that the pressure between two channel is a little bit different, there are some fluctuation. I think this maybe the reason that the calculation is difficult to converge. I am not sure how to solve this problem.
The reynolds number in the pipe is about 6500, but in the gap, almost laminar flow. So now I am using low-Re turbulent model to calculate.
I attached the pressure, velocity distribution along the line that cross of the middle of pipe and the gap.
Ux1 means velocity at z1 position, and Ux2 means the one at z2 position.
Sincerely hope some one can give me some advice.
Thanks.
maolongliu is offline   Reply With Quote
Old   August 15, 2010, 09:05
Maolong LIU
Sorry, I continue to post the distribution of pressure.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Problem with centrifugal pump calculation Michiel Main CFD Forum 2 June 17, 2012 22:32
[FloWorks] Request advice for an airfoil calculation problem Bogey Jammer Main CFD Forum 0 September 29, 2009 18:06
Head pressure loses problem....... krecki CFX 1 March 25, 2008 18:46
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
