August 2, 2010, 06:24 |
Boundary Conditions RANS rhopisofoam
Rep Power: 16 |
Dear CFD friends,
I am very new to OpenFoam. I would like to initialize alphat, epsilon, k mut, omega and R for rhopisofoam RANS. Could someone help me please?, Thank you very much. |
August 22, 2010, 08:13 |
Nilesh Rane
Rep Power: 16 |
Can you please post details about your case and what kinda help you need?? i mean in calculating or setting up or whatever..
Imagination is more important than knowledge..
August 22, 2010, 13:46 |
Rep Power: 16 |
Dear CFD friend,
I have a duct ( inlet, outlet, walls) and the velocity at the inlet is 10 m/s and the pressure at the outlet is 0. If you need more information I can tell you more. Thank you very much. |
August 22, 2010, 15:18 |
Nilesh Rane
Rep Power: 16 |
Well, i am also not very much sure about this, as i am also facing same problems, but would like to tell you what i know. It might help you nevertheless.
alphat =turbulent thermal diffusivity R= Reynolds stress tensor eps = turbulent dissipation rate omega = specific turbulent dissipation rate k = turbulent kinetic energy I think the variables you need to specify depend upon the turbulence model you use. Say you are using k-eps model then you will need to specify k and epsilon and alphat. And in case you need to calculate the actual values for the parameters, you can use the formulas used widely. See following link: http://jullio.pe.kr/fluent6.1/help/html/ug/node178.htm I dont know about specifying values for alphat and R. Hope this helps. just got some more info :-) Please see this post, you will get more info: http://www.cfd-online.com/Forums/openfoam-solving/79323-solver-subsonic-compressible-turbulent-flow-1-7-a.html#post272288
Last edited by nileshjrane; August 22, 2010 at 15:22. Reason: just got some more info :-) |
August 22, 2010, 16:34 |
Rep Power: 16 |
Thank you very much !!!.
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
Pressure boundary conditions | Lionel S. | Main CFD Forum | 1 | August 24, 2007 18:03 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Copying boundary conditions from model to model | Lior | FLUENT | 3 | September 23, 2004 16:10 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
