Meshing Regions Problem
Old   July 21, 2010, 18:24
Default Meshing Regions Problem
m.nichols19 is on a distinguished road
Hi all,
I am in the midst of implementing the chtMultiRegionSimpleFoam solver on a merged mesh that consists of air flowing through an iron pipe. I would like to say it's going well, but it's not.
When I run the splitMeshRegions utility, the output says that there are no "sizes inbetween regions." There should be a value of the number of cells between the regions. I believe this is the reason that the regions are not interacting with one another when I run the solver.
Does anyone have any experience with why this is occurring?
best regards,
Matt
m.nichols19 is offline   Reply With Quote
Old   July 22, 2010, 14:07
Disregard my previous post because I FINALLY have it working. I'll post the solution tonight.
Old   January 12, 2011, 03:09
Miguel Suarez
masuarez is on a distinguished road
matt,
I think i'm working on something similar. I need to create a mesh of a cooling channel (liquid hydrogen running through a rocket chamber). I'm thinking of using chtmultiregionFOam, but i'm having trouble figuring out how to create two separate regions (solid and fluid). I created a similar case in FLUENT, but i'm unable to do so in OpenFOAM.
Can you give me some advice
Miguel Suarez
masuarez is offline   Reply With Quote
How to define cells which belongs to ratating patch in MRFSImpleFoam bharat OpenFOAM Running, Solving & CFD 26 August 18, 2013 19:35
