July 21, 2010, 16:29 |
blockMesh Problem
Dear Foamers,
I've made a mesh with gambit and by using "fluentMeshTofoam *.msh" converted it to OpenFOAM format. Now, boundary, points, face and ... are available in polyMesh folder. i want use incompressible/pisoFoam/les/pitzDaily settings of tutorials. The problem is by typing blockMesh the error "line 141 of blockMeshAPP.C" is shown . when i do same works in icoFoam/cavity folder no error observes. What should I Do? |
July 21, 2010, 17:44 |
Marco A. Turcios
Rep Power: 28 |
You do not need to run blockMesh if you already have a converted FLUENT mesh. blockMesh creates the same files you have mentioned (boundary, points, face, etc. ...) based on the blockMeshDict description of your domain.
Assuming you have properly defined all your boundary conditons, all you need to do now is run the solver on your case. Good luck! |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
