dieselFoam: Summation of total droplet momentum in a Cell
Old   July 17, 2010, 22:11
Default dieselFoam: Summation of total droplet momentum in a Cell
N. A.
N. A. is on a distinguished road
Can someone share their experience on how can total momentum of droplets in a cell be calculated and stored in a a variable. I am new to C++ language and I really need someone's experience in creating a new variables in dieselFoam.
Thanks,
Nir
N. A. is offline   Reply With Quote
Old   July 18, 2010, 00:15
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Thanks,
Nir
You can do it like this
volVectorField moment
IOobject
"moment",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh,
dimensionedVector("moment", dimensionSet(1, -2, -2, 0, 0),vector::zero)
spray::iterator mol(dieselSpray.begin());
for (mol = dieselSpray.begin(); mol != dieselSpray.end(); ++mol)
label cellI=mol().cell();
moment[cellI]+=mol().m()*mol().U();
Junwei
su_junwei is offline   Reply With Quote
Old   July 18, 2010, 00:52
N. A.
Hi Junwei,
Thanks. Is this addition to be made in dieselFoam.C of the solver dieselFoam or should be added in one of the files in the ../src/dieselSpray.. directory.
Thanks,
Nir
Old   July 18, 2010, 05:21
su_junwei's Avatar
su junwei
Hi Junwei,
Thanks,
Nir
I think you can do it in dieselFoam.
Junwei
Old   August 26, 2010, 13:58
N. A.
Hi Junwei,
I wish to add a variable in the lagrangian equations and solve for it. Just as we solve for x,d, m, T, etc for particle properties, I am trying to solve for distorted surface area for each particle and wish to calculate each time-step.
Do you know how another variable be added into lagrangian variables and solve for it.
Any ifnormation will be very helpful.
Thanks,
Nir
Old   August 26, 2010, 22:37
su_junwei's Avatar
su junwei
Hi Nir
You can add a variable into parcel class in /src/lagrangian/dieselSpray/parcel/
1) add variable
2) add read and write access function to this variable
3) add IO operation in parcelIO.C
You can alter the variable like the following code
cloudObject is the particle cloud. yourVariable is your variable name you defined.
for
spray::iterator particle = cloudObject.begin();
particle != cloudObject.end();
++particle
particle().yourVariable()=.... // do as you like.
Regards, Junwei
Old   September 14, 2010, 10:37
Palma González García
Palminchi is on a distinguished road
What a nice topic!
Palminchi is offline   Reply With Quote
Old   September 20, 2010, 08:43
Dear su_junwei,
As far as I understand, if you are multiplying m()*U(), the dimmension of the vector when you defined it before should be (1 1 -1), shouldn't it?
Please, confirm if this is something I don't understand or something I can't see when you make the iterator programming.
And other question is, with the iterator, could I obtain the momentum flux of the droplets(which is m*U^2) ? And do you know how I could obtain the gas momentum?
Best regards and thank you very much,
Palma.
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 15:38
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Warning 097- AB Siemens 6 November 15, 2004 05:41
