October 29, 2010, 09:08 |
#21 |
Rep Power: 17 |
Hi Bruno,
you're right, my residual plot is similar to yours. I know it's just a tutorial case but I have a similar convergence behavior in a real problem (case is very similar to the motorbike case). I don't consider this as converged. The pressure residual is at 0.01 Sure, you can get a good first impression of the flow but nothing more. The values for pressure and velocity should be pretty inaccurate or what would you say? Regards, Toni |
October 30, 2010, 08:20 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Toni,
Allow me to quote myself I also said that there are holes in the motorbike that shouldn't exist. Those holes might be damaging the solution, therefore it won't converge in 500 iterations. AFAIK, the motorBike case was first introduced when snappyHexMesh was included in OpenFOAM. And at that time, it was a tutorial solely for snappyHexMesh, with no set-up for solver execution. So I think it's only natural that the tutorial has not yet been validated with a real experimental data. But if you want to aim for convergence, try AdMesh for plugging the holes in the motorBike STL and increase the number of iterations to 1000-1500. At least it's what I would do, if I really needed it to work... Best regards, Bruno
les, reconstructpar, slow, speed up |
Train Speed | yeo | FLUENT | 5 | February 14, 2012 09:38 |
Can OpenFOAM generate flow at the speed of light? | Michel_sharp | OpenFOAM | 6 | October 24, 2009 05:09 |
Problem with reconstructPar | fabianpk | OpenFOAM | 5 | August 14, 2007 10:17 |
low speed compressible flow | lily | CFX | 2 | November 16, 2005 06:15 |
rotation speed in the domain | jiaye gan | CFX | 3 | April 5, 2004 09:50 |
