July 9, 2010, 10:47 |
fireFOAM convergence
Cristiano
Rep Power: 16 |
Hello everyone,
I have run my simulation 1 week ago. I do not understand the reason for which it takes me a long time. My grid counts around 12000 cells and I think I have set the parameters in controlDict file properly. Any advice? Cristiano |
July 9, 2010, 11:14 |
Rep Power: 16 |
hi christiano,
i think it depends - amongst others - on your computer (clock rate and RAM), the deltaT and endTime in your controlDict and the number of species... i hope this helps, otherwise you should describe your problem more detailled... regards and have a nice weekend |
July 9, 2010, 11:55 |
fireFoam convergence
Cristiano
Rep Power: 16 |
I have run my case (Jet in Hot Coflow) in parallel on two processors. I have got a non confined jet with three different inlets:
air (N2, O2); hot combustion products (N2, O2, CO2, H2O); fuel (CH4). I have checked each parameters in controlDict file and everything should be OK. deltaT=0.0001 (based on the Courant number) maxCo=0.1 maxDeltaT=0.001 What piece of information do you need to understand my problem? Thank You again. Cristiano |
July 9, 2010, 12:35 |
Rep Power: 16 |
so i don't really know, are the residuals still too high? perhaps somthing is wrong in the case and the residuals are oscillating...
has someone else an idea? |
July 9, 2010, 12:47 |
Cristiano
Rep Power: 16 |
I have noticed physical time are not changing during the run. It has been the same for days.
I can read deltaT = 1e-17. For this reason, I should have really high velocity in some point of the domain. ??? |
May 22, 2013, 08:21 |
Bobby
Rep Power: 16 |
Dear Buddies
Hi I want to use fireFoam for simulating DLR flame (Fuel: CH4-H2-N2 and Oxidizer: air); I think I have set my case in proper state; However, After running my case it seems that the jets are still in cold situation and the combustion did not started ; Would some body please hint me what is the problem? I can upload the necessary files i.e. combustion, chemistry, reaction or anythng else Regards Bobi |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Problems with convergence with an easy system | franzdrs | Main CFD Forum | 0 | June 15, 2009 19:17 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 11:55 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 15:20 |
Convergence problems | Chetan | FLUENT | 3 | April 15, 2004 20:13 |
