Thermophysical models and chemistry models
Old   July 15, 2010, 16:06
Default So back to my original question...
  #21
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Sounds like a lot of good discussion came from this thread, which I'm glad about.
However, I'm still needing to calculate the reaction rates without solving the ODE. Any hints? Pretty please?
mturcios777 is offline   Reply With Quote
Old   July 15, 2010, 16:14
Hassan Kassem
hk318i is on a distinguished road
Which model do you want to use to calculate the reaction rates?
hk318i is offline   Reply With Quote
Old   July 15, 2010, 19:08
Marco A. Turcios
I'm using chemistry:
psiChemistryModel ODEChemistryModel<gasThermoPhysics>;
and thermo:
thermoType hPsiMixtureThermo<reactingMixture<gasThermoPhysics >>
I can access the chemistry.solve() function, which acts very much like chemistry.calculate (for ODE chemistry). I was temporarily using a really ugly fix by just replacing the contents of the solve() function with calculate(), and it works. But I have to remember to make changes when I use other solvers that require chemistry.solve(). I'm sure it has something to do with the way things are templatized, but I'm at a loss as to how to deal with it.
Thanks for the help
Old   July 15, 2010, 19:33
Hassan Kassem
I find chemistry models and thermophysical very complicated specially I am trying to understand it myself. I attended openfoam foundation course but these models were not in the scope of the course.
I feel that everyone know something I totally missed. I hope someone will explain soon on wiki or here how these models work.
I am implementing EDM model and it starts to work good but I still need to access the enthalpy of formation of each specie to calculate energy equation source term. Can anyone tell me what is the chemical enthalpy hc()?
Old   July 15, 2010, 20:26
Marco A. Turcios
Ditto brother. I'm sure its just an inheritance thing. I was able to sort of gain access by ensuring that a pure virtual function existed for calculate (I think it was in the psiChemistry.H file), which allowed the scope to be resolved, but then complained that ther function wasn't implemented...
I guess I'll use the ugly hack for the time being...
Old   August 19, 2010, 17:56
Default Diffusion problem.
  #26
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
Originally Posted by smehdi609 View Post
This is the hEqn.h in reactingFoam in Openfoam1.6:
fvScalarMatrix hEqn
fvm::ddt(rho, h)
+ mvConvection->fvmDiv(phi, h)
- fvm::laplacian(turbulence->alphaEff(), h)
DpDt
hEqn.relax();
hEqn.solve();
thermo.correct();
I do not see any source term, I do not think that it solves for sensible enthalpy, are you sure?
I have checked some books, when you contain Hc ( enthalpy of formation) inside h( total enthalpy) you have the reaction reaction source term there. So there is no extra term for reaction. Actually the chemical energy is released when a high energy material like CH4 is decreasing in Y( mass ratio) and a low energy material like CO2 is increasing.
But I have another problem. In this hEqn code, there should be one more term that should compensate enthalpy diffusion due to mass diffusion. I openFoam 1.7 this problem is fixed, because h is hs (sensible enthalpy ) which doesn't need that term. Compare this to equation 1.75 in "Turbulence Combustion" book by Nurbert Peters.
Actually I did one pure diffusion case, that proves reactingFoam in 1.6 has a problem.
SAHM
sahm is offline   Reply With Quote
Old   August 19, 2010, 18:28
Hassan Kassem
you are right, there are no source term for reaction in total enthalpy equation, But I am using the new version which solve the sensibly enthalpy equation which contains a source term for reaction. I do not know how to calculate this term because it needs the enthalpy of formation of each specie which I cannot calculate in OpenFOAM. Do you have any idea how can I get it?
I checked equation 1.75 in Peter's book, but I am not sure if alphaEff() conceder the mass diffusion or not. As I noticed the hs and h equations are identical except the source term.
Old   August 19, 2010, 18:40
Default Trying to figure them out.
  #28
sahm's Avatar
Seyyed Ali H.M.
Actually I was trying to see if I could find how I can have access to Hc like other people. Since I want to use cantera in OpenFoam and that works with OF1.5 ( thanks to Markus Rheim) I had to change the code of reactingFoam to get rid of that problem. So I`m still trying to find out about different parts of this code.
About AlphaEff, I don't know. That alphaEff has to do with turbulence, but my cases are mostly laminar, so I don't know if that works for turbulent properly or not, but in my cases its giving me errors. Also you should notice that this aplha is not temperature diffusivity, it is alpha*cp or k/rho.
I have one more question about YEqn File, but that doesn't go with thread.
If YEqn.H we have muEff which acts simmilar to this alphaEff, the code is:
solve
fvm::ddt(rho, Yi)
+ mvConvection->fvmDiv(phi, Yi)
- fvm::laplacian(turbulence->muEff(), Yi)
kappa*chemistry.RR(i),
mesh.solver("Yi")
I don't know why it is muEff(), I mean it should be effective mass concentration coefficient D or DEff. Do you anything about this?
I have some cases, If you would like to see, I can send them to you, just send me your email.
SAHM
Old   August 19, 2010, 18:50
Hassan Kassem
sure my email is hassan.kassem@gmail.com
http://jeacfm.cse.polyu.edu.hk/downl..._MarzoukOA.pdf
I think this paper is useful. They used reactingFoam. you can check the governing equations.
Old   August 19, 2010, 19:07
Silvano
SilPaut is on a distinguished road
Just a quick note:
In reactingFoam, a transport equation for "total enthalpy " is solved. Total enthalpy is the sensible enthalpy plus the chemical enthalpy. Thus, the transport equation for this variable does not contain any chemical reaction source term, it is conserved in an adiabatic flame. The chemical reaction source terms are provided for the species mass fractions. Once you get the species mass fractions, the "thermo->correct();" method will calculate the heat of formation and desctruction of different species.
can you please help me to understand what "thermo->correct()" do in hEqn.H ?
thanks
Silvano
SilPaut is offline   Reply With Quote
Old   July 13, 2011, 03:16
Achin is on a distinguished road
Hi
I am just starting to explore openfoam. I have a quick question in the following.
autoPtr<basicThermo> pThermo
I understand that in above line pThermo is an object of the template class autoptr.
basicThermo& thermo = pThermo();
But I don't understand is that how the object pThermo is used as pThermo(). I understand that thermo is a reference variable of type basicThermo. Please explain the use of pThermo().
Regards
Achin is offline   Reply With Quote
Old   April 6, 2012, 11:53
Post
  #32
Mostafa Moghaddami
Mostafa is on a distinguished road
Dear All
I am going to run a case includes some liquid species that react with each other. I am going to use the reactingFoam as a solver.
All species have constant proprties and I want to use the following thermo type:
thermoType hsPsiThermo<reactingMixture<constTransport<specieT hermo<eConstThermo<icoPolynomial>>>>>>
but when I set it in the constat/thermophysicalProperties file and run the case, I get this error:
--> FOAM FATAL ERROR:
Inconsistent thermo package selected:
Please select a thermo package based on gasThermoPhysics. Valid options include:
3
hsPsiMixtureThermo<singleStepReactingMixture<gasTh ermoPhysics>>
hsPsiMixtureThermo<multiComponentMixture<gasThermo Physics>>
hsPsiMixtureThermo<reactingMixture<gasThermoPhysic s>>
From function autoPtr<hsCombustionThermo> hsCombustionThermo::NewType(const fvMesh&, const word&)
in file combustionThermo/hsCombustionThermo/hsCombustionThermoNew.C at line 116.
FOAM exiting
What should I do to use the reactingFoam for constant propertie species?
Thanks in advance for your help.
Mostafa is offline   Reply With Quote
Equilibrium Reaction Rates/Gas Chemistry Greg Perkins FLUENT 6 January 6, 2017 03:59
