July 8, 2010, 05:21 |
Missing fields in reconstructPar
Rep Power: 16 |
I am running a decomposed case with interFoam from OF-1.5-dev. When reconstructing with reconstructPar, I get the following output for each timestep (I only copied the last one). Time = 15 Reconstructing FV fields Reconstructing volScalarFields pd p gamma Reconstructing volVectorFields U Reconstructing surfaceScalarFields phi No point fields No tetFem fields No lagrangian fields No FA fields End. I can postprocess fine in Paraview, though. Who can tell me what the point, tetFem, lagrangian and FA fields are and what their use is? |
July 9, 2010, 02:48 |
Claus Meister
Rep Power: 18 |
It seems you have ran an usual Navier-Stokes case, meaning without particle tracking and other addtional stuff. reconstructPar could not find this field, because these were not used, thus not there.
cheers |
fa fields, lagrangian fields, point fields, reconstructpar, tetfem fields |
Problem with reconstructPar: "First token could not be read" | quartzian | OpenFOAM Post-Processing | 2 | October 22, 2015 02:40 |
Bug in decomposePar and reconstructPar | jutta | OpenFOAM Bugs | 1 | March 26, 2010 04:51 |
Problem with paraFoam | ata | OpenFOAM | 14 | November 30, 2009 04:23 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 09:15 |
Problem with reconstructPar | fabianpk | OpenFOAM | 5 | August 14, 2007 09:17 |
