Evaluation of evaporated mass
Old   July 7, 2010, 10:22
Default Evaluation of evaporated mass
mystix is on a distinguished road
Dear FOAMers,
I want to analyse the evaporation constant lambda (called denominator in the evaporation model scripts) over time and for every parcel to compare different evaporation models.
I tried to get the information with implementing the printf command
printf ("denominator = %E \n, denominator")
in the RutlandFlashBoil.C. But it did not work.
Then I implemented
#include "RutlandFlashBoil.H"
Info<< "denominator = " << denominator << " s"
<< nl << endl;
I also tried to get the information of the evaporation constant with ParaView. But there is no data for it.
Any suggestions? Thanks in advance.
Markus
mystix is offline   Reply With Quote
Old   July 7, 2010, 12:37
Nima Samkhaniani
nimasam is on a distinguished road
hi friend
you have 2 options:
1.you can show ur result in log file by adding ur written code exactly after where denominator is calculated
2. you can define ur denominator in creatField.H
somethings like this :
volScalarField denominator
IOobject
"denominator",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar ("denominator",...,0.0)
nimasam is offline   Reply With Quote
Old   July 8, 2010, 05:14
Thank you for answer nimasam.
I added
Info << "denominator = " << denominator << " s" << nl << endl;
exactly after where denominator is calculated in the RutlandFlashBoil.C and compiled the library. But when running the updated case there is no denominator mentioned in the log-file.
Why isn't it shown?
I tried to define the denominator in the creatField.H but I dont find the file using search in whole OpenFOAM-folder. I am using OpenFOAM 1.5.
How is the path of creatField.H?
Thanks in advance. Best regards
Markus
Old   July 8, 2010, 05:22
Nima Samkhaniani
1) do u compile ur solver after change you made ?
2) file name is "creatFields.H" , this file exists in every solver in openFoam
Old   July 8, 2010, 05:43
No, I did not compile the solver, because I think I only have to compile it when I made changes there. Isn't it?
To go for sure I compiled the solver, too. But there is still no denominator mentioned in the log file.
Is the coding correct?
You are right, there is a file createFields.H in many solvers. However I am using the dieselFoam solver and there is no createFields.H.
Is there any possibilty to implement it?
Markus
Old   July 9, 2010, 06:53
Is there a possibilty to analyse the evaporation rate in OpenFOAM?
Old   July 9, 2010, 08:39
I found a solution:
You can analyse the current liquid mass in your system with defaultCloud -> Glyph -> Histogramm -> scalars m.
You know the injected mass because of your massProfil given in the injectorProperties.
You can calculate the evaporated mass.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 15:41
questions about species transport through walls shuqin FLUENT 13 April 9, 2014 03:42
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 11:44
