July 1, 2010, 10:34 |
Time Dependency/ Scale Mesh/ Wall Definition
Robyn
Rep Power: 16 |
I am fairly new to OpenFoam and thus with that come many questions. In any cases with OpenFoam its dependent on the Courant Number. If I enter the controlDict you can define deltaT. Now my question is in regards to steady state cases. Is deltaT time dependent or time iteration dependent? If time dependent why? Next question: How do you scale the mesh? I have a .msh file created in Gambit (completed the fluentMeshToFoam) simple 2D case (channel flow, d=1m) I would like to scale my geometry but only in the x direction ie, change the diameter to 1 cm instead of 1 m. Is this possible in OpenFoam or does the geometry need to be changed in the originial Gambit file? Final Question: In the boundary field how do I know which wall is which? ie in the icoFoam/elbow case there is 2 walls defined (wall-8, wall-4). |
July 2, 2010, 05:46 |
ref. Scaling
Robert Langner
Rep Power: 17 |
Hi Robyn,
this might solve your scaling problem: fluentMeshToFoam -case <case> -scaling '(<xFactor> <yFactor> <zFactor>)' just scale x-Direction: '(0.01 1 1)' |
July 2, 2010, 06:13 |
Robyn
Rep Power: 16 |
Thanks for the response! I'll test it out.
July 2, 2010, 10:50 |
Nima Samkhaniani
Rep Power: 25 |
hi friend
the correct form of scaling command is like below , if u have any hint which help me to have various scaling in different direction it can be helpful fluentMeshToFoam balbla.msh -scale 0.1 or fluentMeshToFoam balbla.msh -scale '0.1' |
July 7, 2010, 05:21 |
#5 | ||
maddalena
Rep Power: 23 |
fluentMeshToFoam balbla.msh Quote:
mad |
July 7, 2010, 05:23 |
#6 | |
maddalena
Rep Power: 23 |
mad |
July 7, 2010, 07:53 |
Robyn
Rep Power: 16 |
Thank you!
July 7, 2010, 09:07 |
#8 | |
Rep Power: 16 |
foamToVTK and then start paraFoam and then open "File/Open" the "VTK"-folder that has been created with foamToVTK. there you can open the main body and the patches, so you can see what is what, by clicking on the "eye" next to the patch name or main body. regards |
simulation not completed in HPDC (thin wall casting) | flyingming | FLOW-3D | 3 | January 20, 2010 12:24 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
