Crank Nicholson scheme for Laplacian failed
Old   June 29, 2010, 12:22
Default Crank Nicholson scheme for Laplacian failed
Cyp
Cyprien
Cyp is on a distinguished road
Hi!
I modify the laplacian discretization scheme into the scalarTransportFoam solver as suggested in the programmer's guide P-43 to implement the crank Nicholson scheme :
solve
         fvm::ddt(rho,T)
      + fvm::div(phi,T)
      - 0.5*(fvm::laplacian(rho*DT,T)+fvc::laplacian(rho*DT,T))
      == ff
where ff is my source term. The compilation is OK. However during runs, my results are wrong. For instance, if I integrate T over the entire domain, the returning result is half the expected one. It looks as if the fvc::laplacian(rho*DT,T) term is not account for.
In my fvSchemes I specify :
laplacianSchemes
    default    none;
    laplacian ((rho*DT),T) Gauss linear corrected;
Do you know how I can solve my problem ?
Regards,
Cyp
Cyp is offline   Reply With Quote
Old   July 16, 2010, 12:12
Michael B Martell Jr
theory37 is on a distinguished road
Try moving
to the right hand side of == (and changing the sign, of course).
theory37 is offline   Reply With Quote
Old   July 19, 2010, 08:36
Cyp
Cyprien
I tried your modification but I still have my problem...
How is your fvSchemes file ??
Old   July 19, 2010, 08:58
The relevant part of my fvSchemes dictionary:
laplacianSchemes
    default         Gauss linear corrected;
although what you have should work fine. Also, what does your ddtSchemes sub-dictionary look like? I'm fairly certain you need to have
ddtSchemes
    default           CrankNicholson 1;
in order for this to work properly, although I'm not sure. If this also doesn't work, perhaps try the exact equation shown in the Programmer's Guide?
Mike
About the Use of Crank Nicholson scheme And OpenFOAM 1 November 14, 2017 13:25
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 07:21
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
Crank Nicholson noName Main CFD Forum 3 September 15, 2004 10:10
