June 29, 2010, 10:09 |
chem_inp and chem_inp.15, DieselFoam
Rickard
Rep Power: 16 |
I was reading the other threads but I still have some questions.
Are chem_inp and chem_inp15 subtitutes? If I e.g. am using C12H26 the reaction is C12H26+18.5O2 -> 12CO2 + 13H20... Do I create the file ELEMENTS H O C N AR END SPECIE C12H26O2 N2 CO2 H2O END REACTIONS C12H26+18.5O2 -> 12CO2 + 13H20 5.00E+8 0.0 15780.0! 1 FORD / C12H26 0.25 / FORD / O2 1.5 / END or something like this ? Under chem_inp 15 they have more reactions. Do I need these? |
July 5, 2010, 06:04 |
Rep Power: 16 |
i don't know the forwardreaction orders (FORD) for dodecane, you should look for a suitable reaction mechanism...
the chem.inp in tutorial aachen bomb is a global reacting mechanism. that means, that there are only reactants and productucts described. the chem.inp_15 is a detailled reaction mechanism, where (all)many elementary reactions are described the difference is that detailled mechanisms describe the case more precise, but as there are more species, more species-equations have to be solved, so the simulation takes longer i think you should start with global mechanism, as you wrote in red, but maybe you have to check the arrhenius rates etc. |
