June 24, 2010, 19:03 |
how to implement non-Arrhenius reaction rate
Hans
I wonder how can I implement non-Arrhenius form reaction rate? For example, the reaction rate of M+N->P+Q is expressed as k=A*f(T), in which T is temperature, and f is an arbitrary function. Thanks for your help. |
June 25, 2010, 15:35 |
M. Mahdi Salehi
Rep Power: 17 |
If it's not an Arrhenius type, then you cannot write it in Chemkin format. Thus, it's not possible to use a Chemkin reader. You should write your own code to calculate the reaction rates. You can still use Chemkin for your thermodynamic model.
January 12, 2018, 06:25 |
K
Rep Power: 9 |
Hello Hans,
I have the same question. Did you find an answer to your question ? In openFoam, we have three parameters A, beta and Ta which are parameters used to describe a rate coefficient following Arrehnius type reactions. I am wondering if we should change source codes (new solver) in OF in order to be able to use non-arrhenius type rate coefficients. Best regards |
surface reaction rate with udf | yellow-stuff | FLUENT | 4 | January 29, 2010 12:53 |
UDF changing the rate exponent of a reaction | Stefan H | Fluent UDF and Scheme Programming | 0 | September 16, 2009 13:20 |
surface reaction rate | zhou | FLUENT | 4 | October 2, 2003 16:16 |
Plotting Surface Reaction Rate | Ryan | FLUENT | 0 | February 12, 2003 14:47 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
