sample utility stops sampling once the line leaves the domain
Old   June 17, 2010, 05:35
Default sample utility stops sampling once the line leaves the domain
Zymon is on a distinguished road
I want to sample my results along a couple of lines after the simulation. The sample utility should be perfect for this, but I have a Problem. I want uniformly distributed points along the line, so I chose uniform as the sampling type. When the line leaves my domain the sampling stops and the last result in the new written file is the last point in my domain. But the line reenters the domain at another location and the sampling does not start at this position again. I hope you understand what I mean. Once the line leaves the domain the sampling stops and does not go on again when the line reenters the domain.
Maybe someone else had the sample problem. I tried to change the sampledSets.C, but I can't find the right lines in the code. Of course, it works when I define a point cloud of the points along the line. But this is a bit inconvenient.
Edit: Ah, and I would like to write e.g. zeros for the velocity components of the points on the line that are not inside the domain. When I construct a point cloud these points are ignored at all in the file.
Thanks
Zymon is offline   Reply With Quote
Old   May 2, 2012, 05:51
pyt
Pavel Tomin
pyt is on a distinguished road
Hi Zymon,
Did you solve the problem?
pyt is offline   Reply With Quote
Sample utility Gearb0x OpenFOAM Post-Processing 13 April 30, 2019 13:16
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger benru OpenFOAM Meshing & Mesh Conversion 3 June 29, 2008 22:24
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
