problems with compiling self defined class
Old   June 15, 2010, 04:51
Unhappy problems with compiling self defined class
Victor Fleischer
Victor is on a distinguished road
Hi at all,
i tried to implement my own class(class Tracing) which follows the flameFront and writes the current position of the flame to a file.
So i wrote two files:
Tracing.H
Tracing.C
After including flameTrace.H in my solver and creating an Object of this class by
Tracing flameTip;
and using the two methods for following the flame and write the position to the file, by:
flameTip.follow();
flameTip.write();
I allways get this error message while compiling the solver:
Make/linux64GccDPOpt/reactingTotalFoamFE2.o: In function `main':
reactingTotalFoamFE2.C.text+0x338f): undefined reference to `main::Tracing::Tracing()'
reactingTotalFoamFE2.C.text+0x9bdf): undefined reference to `main::Tracing::~Tracing()'
reactingTotalFoamFE2.C.text+0xa74b): undefined reference to `main::Tracing::follow()'
reactingTotalFoamFE2.C.text+0xa79e): undefined reference to `main::Tracing::writeToFile()'
reactingTotalFoamFE2.C.text+0xdb2a): undefined reference to `main::Tracing::~Tracing()'
collect2: ld returned 1 exit status
make: *** [/nfs/home/fleischer/OpenFOAM/fleischer-1.6.x/applications/bin/linux64GccDPOpt/reactingTotalFoamFE2] Error 1
I don't know what "undefined reference to main::Tracing::....." shoud mean!?
Can anybody help me please!
Thanks a lot in advance!
Victor
Victor is offline   Reply With Quote
Old   June 15, 2010, 05:19
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
That seems odd. Have you changed Make/options and/or Make/files as well? Is this part of a library or are you compiling it with the solver?
And are you sure you meant flameTrace.H instead of Tracing.H:
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   June 15, 2010, 06:02
Victor Fleischer
Thank you l_r_mcglashan, I think there are different problems but the basic one is that i didn't know that i need a make-folder for compiling the header file correctly.
I think i will try the whole thing in a easier way....but thanks a lot for your help!
Old   June 15, 2010, 06:07
Grabbing an example from the sources, have a look at the application heatTransfer/chtMultiRegionFoam. See how the regionProperties class is used.
Old   June 15, 2010, 06:38
Victor Fleischer
Thank you, the regionProperties helps a lot. The problem I have at the moment is that my class Tracing needs the mesh information for calculating the flame position. For example I have to use mesh.C(). I don't know how to handle this, because I don't know how to deliver the mesh Information to my header file.
I tried to use a genererell objectRegistry in the the constructor Tracing(objectRegistry reg0,...), but there doesn't exist a .C() data.
Perhaps you know an example of an header-file that uses the mesh data in any way!?
Something i also do not understand is the declaration of a namespace
namespace Foam
before the declaration of the class. Could you explain to me, why this is necessary?
Victor
Old   June 15, 2010, 07:11
Pass the mesh as an argument to the constructor:
header file:
class Tracing
    const fvMesh& mesh_;
    Tracing
        const fvMesh& mesh
source file:
Foam::Tracing::Tracing
    const fvMesh& mesh
    mesh_(mesh)
Then you can use mesh_ in that class.
The Foam namespace isn't declared before the class,. The class is part of the namespace Foam. So Foam::regionProperties is its full name. In chtMultiRegionFoam.C you'll see:
regionProperties rp(runTime);
The full type would be Foam::regionProperties rp(runTime); but in the fvCFD.H file there's a using namespace Foam declaration.
Old   June 21, 2010, 03:54
Victor Fleischer
Oh, thank you really much! This is exactly I was looking for!
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 06:06
Problems compiling under 14 grtabor OpenFOAM Running, Solving & CFD 9 July 17, 2007 23:34
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 19:18
Some problems with Star CD Micha Siemens 0 August 6, 2003 14:55
Compiling MON FLUENT 0 October 20, 2002 21:48
