Saving and restoring ParaView postprocessing
Old   June 11, 2010, 06:52
Default Saving and restoring ParaView postprocessing
Christoph
kriz is on a distinguished road
Hi!
After making lots of slices, glyph's and stream-traces for visualisation within ParaView, I am asking myself, is there a possiblity to save all this postprocessing work and to load it thereafter?
"Save data" and "Save state" does not seem to do this?
kriz is offline   Reply With Quote
Old   June 11, 2010, 09:39
Zymon is on a distinguished road
Yeah, good question. I had the same problem, but couldn't find a solution too. When I save a screenshot or an animation paraView crashs most often (I don't know why). So it is quite annoying when I want to take another screenshot and have to set all the slices and glyphes again.
Zymon is offline   Reply With Quote
Old   June 11, 2010, 10:13
Anonymous
madad2005 is on a distinguished road
Originally Posted by kriz View Post
Hi!
Go to Tools->Python Shell. There should be a tab called 'trace' which will record everything you do as a Python macro, which you can then run at a later date to replicate everything you did previously. Save state should do something similar as well and I'm not sure why you are having issues with it.
madad2005 is offline   Reply With Quote
Old   June 12, 2010, 06:59
Claus Meister
idrama is on a distinguished road
Hallo madad2005,
I did what you have wirtten, but all what I get is:
Python Shell is not Available
What do I do?
idrama is offline   Reply With Quote
Old   June 13, 2010, 07:46
Christoph
Thanks for the hints!
Old   June 13, 2010, 08:28
Claus Meister
Hello madad2005,
I have managed it to get the python shell; I re-compiled paraview. Unfortunately, I have no access to trace; its does not appear. What can I do?
Old   June 14, 2010, 04:38
Anonymous
Originally Posted by idrama View Post
Hello madad2005,
If your version of ParaView is 3.6.1 or older, then you won't have access to trace. It was only included from 3.6.2 onwards. Personally, I suggest you download the latest ParaView 3.8.0. Not only does this have access to trace functionality, but it also includes Takuya et al.'s OpenFOAM reader (I believe). If you don't want to have to do this, then double-check Save/Load State to make sure it works for you again.
