Wildland surface fire representation in OpenFOAM
Old   June 4, 2010, 13:07
Post Wildland surface fire representation in OpenFOAM
Paulo Bufacchi
Bufacchi is on a distinguished road
Hello all.
I'm working on my PhD thesis at University of Sao Paulo in Brazil. It is about wildland surface fire (vegetation is up to 1.8 meter tall). I decided to use OpenFOAM and not any other commercial tool. I'm using OpenFOAM version 1.6 on OpenSuse 11.1 (64 bits platform). As a beginner, I read the user's and programmer's guides, I went through the tutorials on the user's guide, I read many posts on the OpenFOAM forums and searched the src directory for information on the codes and their usage.
The physical model for a wildland surface fire is divided into a vegetation region and the atmosphere just above it. The vegetation is heated, dehydrates (looses water), undergoes pyrolysis (where reacting components are produced), and oxidates (surface burning). The reacting pyrolysis components reacts on the atmosphere. There are convection and radiation heat transfer to the air and to the vegetation surrounding the fire. The relative importance of each heat transfer type depends on the ambient wind. After burning, the vegetation becomes coal and ash.
The mathematical model I envision is a two domain (or region), where the vegetation is a porous media. As the air velocity is small, I plan to use a low Mach number approach (Navier-Stokes derived equations), which eliminates the acoustic waves (the spatially nonuniform portion of the pressure appears only in the momentum equation). Then, density varies with temperature, but not with pressure. Turbulence is everywhere and LES is used to model it. Buoyant flow rules the hot air (due to the fire) spread. The simulation is all transient.
To represent the model above, I was thinking to use chtMultiRegionFoam, replacing the solid region by a porous media code. The question that arises is the OpenFOAM code to use (or begin with and then change), because the porous media has to shrink as fire moves downstream consuming vegetation that becomes coal and ash.
I would appreciate comments and hints that can guide me through OpenFOAM in order to represent the model described above, and what codes to use or start with.
Thanks in advance.
Bufacchi is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
openFoam for fire dynamic simulation hadi1982 OpenFOAM 2 November 2, 2009 06:30
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
