Incompressible Turbulence models
Old   May 26, 2010, 07:27
Default Incompressible Turbulence models
achinta
achinta is on a distinguished road
I am new to OF and want to learn how turbulence models are used in it.
There are tutorials which use k-epsilon and k-omega-sst models.
I want to try other turbulence models like q-zeta model, Spalart-Allmaras model and LES models like Smagorinsky, k-omega-sst-SAS and various other models given in OF.
Are there any tutorials using these models?
I need them to know the input files required to define constants and other inputs to the model.
Thank You
Regards,
Achinta
achinta is offline   Reply With Quote
Old   May 26, 2010, 07:29
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
The model constant can be found in the codes of this models
Originally Posted by achinta View Post
Thank You
Regards,
Achinta
waynezw0618 is offline   Reply With Quote
Old   May 26, 2010, 07:37
achinta
I saw some files in $HOME/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/RAS/qZeta
I am not able to understand which one should be given as input in 0/ folder (initial conditions). I want to know the syntax of the inputs.
Thank You.
Regards,
Achinta
Old   May 26, 2010, 12:45
wayne.zhang
by default the modeling constant do not need to be modified
and it is not put in the 0/ directionary
Old   May 27, 2010, 11:35
achinta
I want to use Lien Cubic K-Epsilon model for incompressible turbulent flow. Which divergence scheme is best for nonlinearStress i.e. div(nonlinearStress)?
Thank You.
Regards,
Achinta
Tutorials for incompressible flow and different turbulence models Sandu69 OpenFOAM 2 April 20, 2010 13:17
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 16:39
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
