Rotational periodic Boundary condition
Old   May 26, 2010, 07:09
Default Rotational periodic Boundary condition
achinta
achinta is on a distinguished road
hi,
I need to use rotational periodic boundary condition for my model. I used 'cyclic' boundary condition for 2 planes and OF gave the following error.
Create time
Create mesh for time = 0
face 0 area does not match neighbour 1021 by 123.634% -- possible face ordering problem.
patch:SYM1 my area:3.13674e-06 neighbour area:1.32932e-05 matching tolerance:0.001
Mesh face:2900402 vertices:3((0.00766235 0.0434244 0) (0.00210264 0.0462494 0) (0.00291487 0.0469651 0))
Neighbour face:2901423 vertices:3((0.00390903 0.00637109 0) (0.00794004 0 0) (0.00376707 0 0))
Rerun with cyclic debug flag set for more information.
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 180.
FOAM exiting
How can I improve my mesh to use cyclic boundary condition?
Are there any other methods to define rotational periodic boundary condition?
Thank You.
Regards,
Achinta
achinta is offline   Reply With Quote
Old   May 26, 2010, 07:16
achinta
I tried to use 'wedge' boundary condition on 2 planes to define rotational periodic condition for my model. OF gave the following error.
Create time
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/logau/expsm/OpenFOAM/OpenFO
AM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/
#2 ?? in "/lib64/libc.so.6"
#3 Foam::wedgePolyPatch::initTransforms() in "/usr/logau/expsm/OpenFOAM/OpenFOA
#4 Foam::wedgePolyPatch::wedgePolyPatch(Foam::word const&, Foam::dictionary con st&, int, Foam:olyBoundaryMesh const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM- 1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam:olyPatch::adddictionaryConstructorToTable<F oam::wedgePolyPatch>::New( Foam::word const&, Foam::dictionary const&, int, Foam:olyBoundaryMesh const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam:olyPatch::New(Foam::word const&, Foam::dictionary const&, int, Foam:: polyBoundaryMesh const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64G ccDPOpt/libOpenFOAM.so"
#7 Foam:olyBoundaryMesh:olyBoundaryMesh(Foam::IOo bject const&, Foam:olyMe sh const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpe nFOAM.so"
#8 Foam:olyMesh:olyMesh(Foam::IOobject const&) in "/usr/logau/expsm/OpenFOA M/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#9 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/usr/logau/expsm/OpenFOAM/Op enFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#10 main in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64Gcc DPOpt/simpleFoam"
#11 __libc_start_main in "/lib64/libc.so.6"
#12 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start .S:116
Floating decimal point exception
What could be the reason? I am new to OF and I am not able to understand what the error says.
Thank You
Regards,
Achinta
Old   May 27, 2010, 05:04
Default suggestions
maddalena's Avatar
maddalena
maddalena will become famous soon enough
so your problems have been not fixed yet...
This will not work for sure if your model is 3D! wedge requires that the mesh is only one cell thick!
hi,
Create time
Please check that:
  1. your plane mesh must be the equal; use a constraint on your meshing software to keep the plane identical.
  2. check that your cyclic domain is formed only by two coupled planes, and not by multiple planes. Every cyclic plane must be connected to its counterpart! i.e. if you have 2 couples of 2 cyclic planes, define them in polyMesh/boundary separately.
If you have already done that, try to increase the matching tolerance in createPatchDict. Try to increase it little by little, as soon as the two planes match.
Hope this help,
cheers,
maddalena
maddalena is offline   Reply With Quote
periodic boundary condition in LES martor FLUENT 3 April 30, 2022 01:20
Theory for periodic boundary condition Hashmi CFX 6 November 14, 2012 17:41
Periodic Boundary condition Aerodecom FLUENT 2 May 30, 2007 02:03
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 09:39
periodic boundary condition dipak Phoenics 1 November 16, 2000 05:51
