Questions about tutorial from User Guide :confused:
Old   May 25, 2010, 11:50
Smile Questions about tutorial from User Guide :confused:
inginer's Avatar
Ovidiu Michiu
inginer is on a distinguished road
I'm very new in OpenFOAM and i already have a lot of problems in running the first tutorial. I manage to install OF 1.6 on a Suse distribution, 32 bits(my conection is to a server,VNC).
After i copy all the tutorials on a separated file, i try to run "cavity". I did all the steps from the user guide and after I run the "blockMesh" comand, i want it to see the mesh with paraview and i could saw it. WHY? also, it wasn't created any cavity.openFOAM file.
i went to the next step to run the analysis, by typing "icoFoam". it mayed the analysis, but still it any cavity.openFOAM (cavity.foam) file wasn't created it. WHY?
I try to run other simple cases, like "cylinder", from potentialFOAM directory, but i had the same problem like at the first one. also, when i typing "icoFoam" comand i receive this error:
Create time
Create mesh for time = 0
Reading transportProperties
cannot open file
file: /root/OpenFOAM/run/tutorials/basic/potentialFoam/cylinder/constant/transportProperties at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
The same error apear for other cases that i want it to run.
Can somebody give me some advices or answers???
Thk you,
Best regards,
Ovidiu
inginer is offline   Reply With Quote
Old   May 25, 2010, 12:46
Alberto Passalacqua
It seems it just doesn't find the transportProperties file.
How do you try to run paraview and from where (you have to be inside the case directory or specify the path with the command line options)?
The "cavity.foam" file is created by paraFoam and removed when you close it.
Best,
Alberto Passalacqua
Old   May 25, 2010, 13:42
inginer's Avatar
Ovidiu Michiu
ok. it worked, but another problem appeard.
If I'm typing paraFoam, the "cavity.openFOAM" file is created in paraview, but on the screen appear a box with Microsoft visual studio and the following error
"an unhandled win32 exception occured in Xming.exe[5084]
Possible Debuggers:
New instance of Visual Studio 2005
New instance of Visual Studio 2008
Do you want to debug using the selected debugger?"
If im selection "yes" the program is not responding
if im selected "no" close the paraview.
my connection is to a linux server at the distance.
best regards,
Ovidiu
Old   May 25, 2010, 13:53
Alberto Passalacqua
No idea. I use OpenFOAM on Linux. Sorry.
Alberto Passalacqua
Old   May 25, 2010, 16:10
Retired Super Moderator
Bruno Santos
Greetings to all,
Possible Debuggers:
Well, something similar to this happened to me just today, also when using Xming in Windows, but for me, it was Putty (the ssh client) who crashed. I haven't got a clue as to why, i can only assume it was a protocol error that occurred between server, Putty and Xming As for solutions, I haven't worried about fixing it
If you still want to use ssh with X11 forwarding, perhaps you can try:
  • Cygwin with X server installed, and use "ssh -X" directly from the Cygwin shell.
  • or install a Virtual Machine or Virtual Appliance with a Linux box in it, and then do the remote connection from there.
Best regards,
Bruno
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
CFX User Guide query siw CFX 0 August 21, 2008 04:15
particle user routines Felix CFX 1 July 24, 2006 13:32
confused about particle user source sub-routine wayne CFX 1 August 30, 2005 07:55
Fluent 6.1 user guide dingdong FLUENT 6 May 17, 2004 12:17
