OpenFoam and Fluent compressible flowComparison |
Seyyed Ali H.M.
Rep Power: 16 ![]() |
Dear All
Recently I have been running some cases with OpenFoam for a backward facing step. In these cases, I tried to keep the Re=500 and change Ma from 0.1 to 0.4, In all the cases the T=224K was fixed. so Vi and h was calculated with Ma and Re constraints respectively. The attached graphs shows the change in the Normalized velocity Vx versus normalized height in section x/h=1 in all the cases. I know why the normalized velocity is increased as seen the graph section1.pdf ![]() Then I tried to do the same case with Fluent. but when I created this graph, I saw a big difference between Fluent and OpenFoam results, as seen in file OpenFoam-Fluent-1-2.pdf. Can anybody tell me why this big difference happens. ![]() I tried the fluent case with 2nd order calculations, as seen in graph OpenFoam-Fluent-1-2nd.pdf but as you see, the profile doesn't change that much. Now I`m trying to run the same case in OpenFoam with second order calculations (If I find how to do it) Can anybody help me with this problem. If you want to know, I can send you more details about the cases. |
Yu
Dear Sahm,
I have also found relatively huge differences between OpenFOAM and Fluent in compressible flow. Which Solvers did you use? |
OpenFOAM vs. Fluent & CFX | marco | FLUENT | 16 | November 17, 2020 04:53 |
Difficulty running an inviscid compressible nozzle flow using OpenFOAM | rbozinoski | OpenFOAM Running, Solving & CFD | 11 | December 29, 2015 07:19 |
Fluent elbow in Openfoam | chemeng | OpenFOAM | 1 | January 21, 2010 03:52 |
OpenFOAM vs. Fluent & CFX | marco | Main CFD Forum | 81 | March 31, 2009 14:22 |
OpenFOAM vs Fluent for cylinder at Re%3d150 | lr103476 | OpenFOAM Running, Solving & CFD | 40 | December 18, 2008 09:09 |
