Explanation bounding k and bounding epsilon
Like Tree33Likes
Old   July 13, 2017, 04:09
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
bounding problems for my experience can be only fixed for the skewed meshes can be solved using "upwind" convective scheme along with "cellLimited" gradient schemes. Ones you go for the second order in the convective schemes, you always get some unboundness of the transported scalars.
Cheers,
Alex
Imran358 likes this.
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   July 13, 2017, 05:01
rmz
rmz
rmz is on a distinguished road
Hello Dr. VAKHRUSHEV and thank you for your reply,
for the "gradSchemes" I am using cellMDLimited Gauss linear 1.
Whould you recommend the the "cellLimited" or "cellMDLimited" ?
for the "divSchemes" I am using:
-bounded Gauss upwind for "div(phi, epsilon)" and "div(phi, k)".
-bounded Gauss limitedLinear 1 for "div (phi,U)", because I had convergence problems and this scheme helped fix the convergence.
for "snGradSchemes" I am using limited 0.333
these schemes helped fixing bounded problems, but bounded k and epsilon are still appearing after approx 800 steps.
Which is better to use for the gradSchemes "cellLimited" or "cellMDLimited"?
Thank you
rmz is offline   Reply With Quote
Old   July 13, 2017, 05:05
as far as I remember cellMDLimited makes sence only for vector fields, and it additionally make some distortions in the solution, so I stick to cellLimited
rmz likes this.
Best regards,
bounding error, simplefoam stability
Bounding epsilon or bounding omega Stylianos OpenFOAM 8 February 23, 2018 14:41
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 03:11
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
Bounding epsilon and K with rasInterFoam openfoam_user OpenFOAM Running, Solving & CFD 0 October 23, 2008 09:48
