Subsonic Poisselle flow
Old   May 16, 2010, 12:12
Default Subsonic Poisselle flow
Ehsan
ehsan is on a distinguished road
Hi there,
I am simulating subsonic channel flow (Poisselle flow) with rhoCentralfoam, but my solution is incorrect when I go ahead.
The error is that the flow reverses very soon and return back to the inlet (reverse flow).
I simulate half channel: bottom plate is wall, upper plate is symmetryPlane.
The BC's are:
Pressure:
inlet
type totalPressure;
p0 uniform 1.0487e5;
U U;
phi phi;
rho none;
psi none;
gamma 1.4;
value uniform 1.01e5;
outlet
// type fixedValue;
// value uniform 65000;
type zeroGradient;
top
type symmetryPlane;
wall
type zeroGradient;
Velocity:
inlet
type pressureInletVelocity;
phi phi;
value uniform (81.37 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (200.0 0 0);
wall
type slip;
top
type symmetryPlane;
Temperature
inlet
type fixedValue;
value uniform 300.0;
outlet
type inletOutlet;
inletValue uniform 300.0;
top
type symmetryPlane;
wall
type zeroGradient;
If any ones like, I will send him total files.
Thanks in advance,
ehsan is offline   Reply With Quote
Old   December 24, 2013, 05:29
Javad
javad1404 is on a distinguished road
Hi ehsan
Could you solve this problem?
If the answer is yes, could you please tell me how you could solve it?
thanks in advance
regards
javad1404 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
subsonic Airfoil Flow husker OpenFOAM 10 March 3, 2013 18:17
subsonic nozzle flow, inlet-outlet BCs felix Main CFD Forum 3 May 15, 2006 11:37
Subsonic flow in a supsersonic nozzle Laplacien FLUENT 0 April 6, 2006 04:27
