Newer Janaf Model
Like Tree14Likes
Old   June 24, 2011, 22:03
桂莹
yingkun is on a distinguished road
Hi,Thomas
I chang the species temperature rangs in therm.dat file,it works,the only thing is that I need to know whether the result is correct,I'm going to check it...
yingkun is offline   Reply With Quote
Old   June 26, 2011, 02:05
T. Hoffmann
bfisch90 is on a distinguished road
Hallo Yingkun,
maybe you could try to find out, if the nasa database has new thermodynamic data for your species, which are valid for temperatures up to 6000 K.
http://www.grc.nasa.gov/WWW/CEAWeb/ceaThermoBuild.htm
Good luck
Thomas
febriyan91 likes this.
bfisch90 is offline   Reply With Quote
Old   June 26, 2011, 08:27
桂莹
it's good for me,thanks!
Old   September 30, 2011, 19:49
R. P.
Rophys is on a distinguished road
Hello all,
I tried to use the NASA web site but I didn't understand so much the output.
For example, I choose the element N (atomic nitrogen) and after this I choose N2 (molecular nitrogen). Next step, I choose the temperature range from 273 to 500 K, and I get the following output :
N2
OPTIONS: joules
TEMPERATURE SCHEDULE
273.000 283.000 293.000 298.150 303.000 313.000
323.000 333.000 343.000 353.000 363.000 373.000
383.000 393.000 400.000
NOTE: Thermodynamic properties calculated for temperatures outside the range of
the fitted data may have large errors. This program allows calculations only
for temperatures within 20% above or below the fitted temperature range.
COEFFICIENTS FOR FITTED THERMODYNAMIC FUNCTIONS
N2 Ref-Elm. Gurvich,1978 pt1 p280 pt2 p207.
3 tpis78 N 2.00 0.00 0.00 0.00 0.00 0 28.01340 0.000
200.000 1000.000 7 -2.0 -1.0 0.0 1.0 2.0 3.0 4.0 0.0 8670.104
2.210371497E+04-3.818461820E+02 6.082738360E+00-8.530914410E-03 1.384646189E-05
-9.625793620E-09 2.519705809E-12 0.000000000E+00 7.108460860E+02-1.076003744E+01
1000.000 6000.000 7 -2.0 -1.0 0.0 1.0 2.0 3.0 4.0 0.0 8670.104
5.877124060E+05-2.239249073E+03 6.066949220E+00-6.139685500E-04 1.491806679E-07
-1.923105485E-11 1.061954386E-15 0.000000000E+00 1.283210415E+04-1.586640027E+01
6000.000 20000.000 7 -2.0 -1.0 0.0 1.0 2.0 3.0 4.0 0.0 8670.104
8.310139160E+08-6.420733540E+05 2.020264635E+02-3.065092046E-02 2.486903333E-06
-9.705954110E-11 1.437538881E-15 0.000000000E+00 4.938707040E+06-1.672099740E+03
According to the User Guide (U-177) Cp is calculated as follow:
Cp=R((((a1T+a3)T+a2)T+a1)T+a0)
and we need 2 constants of integration a5 and a6.
My question is, which of this parameters corresponds to a0, a1, a2, a3, a4, a5 and a6 ? If this website is not properly to obtain this value, there is another reference ?
My apologise for this question, it is a bit long
Rophys is offline   Reply With Quote
Old   October 6, 2011, 04:39
T. Hoffmann
Hallo,
the output of the NASA-database is based on the newer Janaf model with 9 coefficients (a1-a7, b1, b2).
a1 a2 a3 a4
a5
1.384646189E-05
a6 a7 placeholder
b1 b2
Equations newer Janaf model
Cp(T) = R( a[1]/T^2 + a[2]/T+ a[3] + a[4]T + a[5]T^2 + a[6]T^3 + a[7]T^4 )
H(T) = R( -a[1]/T + a[2]lnT + a[3]T + (a[4]T^2)/2 + (a[5]T^3)/3 + (a[6]T^4)/4 + (a[7]T^5)/5 + b[1] )
S(T) = R( -a[1]/(2*T^2) - a[2]/T + a[3] lnT + a[4]T + (a[5]T^2)/2 + (a[6]T^3)/3 + (a[7]T^4)/4 + b[2] )
The official version of OpenFOAM has implemented only the old Janaf model.
So you have different choices e.g.:
- Convert the thermodata (from the NASA database) into the old format
- Implement the newer Janaf model to OpenFOAM
http://openfoamwiki.net/index.php/Janaf4
- use a thermodata file which is already in the old format and contains the species you need.
ftp://ftp.technion.ac.il/pub/support...mics/THERM.DAT
Thomas
Originally Posted by Rophys View Post
Hello all,
N2
OPTIONS: joules
dokeun, amolrajan and usv001 like this.
Old   October 6, 2011, 07:23
R. P.
Hi Thomas,
Thanks for this. Again I have two more questions.
1) The file therm.dat only give me information about a0....a4. How can I calculate the a5 and a6 (constants of integration). ?
2) Taking in to account the air data, which line corresponds to high and low temperature coefficients ? And the common temperature ?
AIR L 9/95 WARNING! 0G 200.000 6000.000 1000. 1
3.08792717E+00 1.24597184E-03-4.23718945E-07 6.74774789E-1-3.97076972E-15 2
-9.95262755E+02 5.95960930E+00 3.56839620E+00-6.78729429E-04 55371476E-06 3
-3.29937060E-12-4.66395387E-13-1.06234659E+03 71582965E+00-1.50965000E+01 4
line 1
200.000 - lower temperature limit
6000.000 - upper temperature limit
1000 - common temperature
line 2
corresponds to low cp coeff ?
line 3
corresponds to high cp coeff ?
line 4
corresponds to common temperature cp coeff ?
Is it correct ?
Thanks very much
Old   October 6, 2011, 07:45
T. Hoffmann
Hallo,
In the old janaf tables, you have only two temperature ranges (low and high). The first 7 parameters belong to the high temperature range. a5 and a6 are the constants of integration.
(You could test this by just plotting cp, h and s.)
The janaf table with 15 coefficients is an updated version:
The 7 term polynomials actually include 15 constants. The first set of 7 constants belongs to the 1000-6000 K polynomial, the second set of 7 constants belongs to the 200-1000 K polynomial, and the fifteenth constant is H298/R ≡ ΔfH298/R.
Thomas
high temperature range (1000K-6000K)
a0 a1 a2 a3 a4
a5 a6 low temperature range (200K-1000K) a0 a1 a2
a3 a4 a5 a6 H298/R
Cp(T) = R( a[0] + a[1]T + a[2]T^2 + a[3]T^3 + a[4]T^4 )
H(T) = R( a[0]T + (a[1]T^2)/2 + (a[2]T^3)/3 + (a[3]T^4)/4 + (a[4]T^5)/5 + a[5] )
S(T) = R( a[0] lnT + a[1]T + (a[2]T^2)/2 + (a[3]T^3)/3 + (a[4]T^4)/4 + a[6] )
Hi Thomas,
line 1
line 2
line 3
line 4
Is it correct ?
Thanks very much
Old   October 6, 2011, 08:09
R. P.
Hi Thomas,
Thanks for this.
Now is very clear to me the janaf table.
Old   December 6, 2011, 09:08
Default download link is not avaible
  #29
MPJ
Oliver Pasqual
MPJ is on a distinguished road
hello everyone,
it seems that the download link for the new janaf table in the openfoamwikiis not avaible now.
The URL of openfoamwiki is:
can somebody send me a copy of these file?
my email address is oliver.pasqual@gmail.com
Thanks
oliver P
MPJ is offline   Reply With Quote
Old   December 6, 2011, 10:08
R. P.
MPJ,
The new JANAF table is not implemented in the OpenFoam. In your simulation you need to use the values from the old table. The link that you sent in your post there contains both tables (old and new JANAF).
old JANAF: ftp://ftp.technion.ac.il/pub/support...mics/THERM.DAT
new JANAF: http://www.galcit.caltech.edu/EDL/pu...rmo/thermo.inp
Regards,
Rodrigo
Old   December 7, 2011, 10:06
MPJ
Oliver Pasqual
MPJ,
Regards,
Rodrigo
Hi Rodrigo,
thanks for your kindly reply.
sorry for the undetailed description.
The janaf table can be obtained, but the URL for new janaf model is not avaible.
it's the message from the developer that the link will be updated soon(Thx, Thomas)
Have a nice day
Oliver
Old   May 2, 2012, 10:33
MPJ
Oliver Pasqual
hello everyone,
The downloading URL for new janaf model in the wiki is not avaiable for a long time.
I want to obtain these files, so it will be highly appreciated if someone send me a copy of these file or tell me where I can get them.
oliver
Old   May 2, 2012, 19:45
R. P.
Dear Oliver,
Just download the new Janaf using the following link:
open the website, copy all the data (ctrl+a) and paste it in .txt file (you can create a .txt using a text editor like notepad).
Cheers.
amolrajan likes this.
Old   May 7, 2012, 10:33
MPJ
Oliver Pasqual
Dear Oliver,
Cheers.
Dear Rophys,
Thanks for you kindly reply and your patient help.
yes the janaf table can be obtained from URL your given.
From the openfoamwiki
( http://openfoamwiki.net/index.php/Janaf ),
we got:
The old janaf tables uses 7 coefficients and 2 polynomials for a lower and a higher temperature range,and the old janaf tables are valid for temperatures up to 6000 K.
The newer janaf model can be used to handle a larger temperature range up to 30000 K.
But the temperature dependent values of Cp, H and S are calculated with 3 polynomials using 9 coefficients.
so only obtain the new janaf tables has none effect on solving the problem. firstly we should replace the older janaf model source code files, and then compile to refresh the library.
but the source code URL describeds in the install section of wiki is not avaible for a long time.
that is :
2.2.1 How to install
1.Download and unzip the following folders:
http://www.daten.media-agentur-hof.d...land150411.zip
http://www.daten.media-agentur-hof.d...lich/janaf.zip
http://www.daten.media-agentur-hof.d...ader160411.zip
also the test case can't be download now.
so if you have the source code file and the test case files, could you send me a copy of them.
My email address is: oliver.pasqual@gmail.com
Great thanks!
oliver
Old   July 13, 2012, 09:52
Ali Shamooni
Alish1984 is on a distinguished road
Originally Posted by MPJ View Post
Dear Rophys,
we got:
that is :
Great thanks!
oliver
I have the same problem. the link to .zip source files is down. any one can help???
Alish1984 is offline   Reply With Quote
Old   October 23, 2013, 08:22
Default Using Newer Janaf Model in OpenFOAM -2.2.0
  #36
Punit Walia
Punit Walia is on a distinguished road
I am working on a temperature range of 1000-15000K. So i need to use newer janaf tables which have temperature range till 20000K. I have worked using the old janaf tables.. but near 4000 initial temperature, it goes out of range. Please help me to implement the new janaf model with 9 coefficients. I am using openFOAM version 2.2.0.
Thank you,
Punit Walia
Punit Walia is offline   Reply With Quote
Old   October 24, 2013, 08:12
Punit Walia
Hi Arvind,
I have to use Newer Janaf model in OpenFOAM-2.2.0. Please can you send me the source code files and the procedure to follow to implement it in 2.2.0 version of openfoam.
My email id is punit.iitb@gmail.com
Thank You
Regards,
Punit Walia
Old   May 5, 2014, 23:13
Daniel
dancfd is on a distinguished road
Hello all,
Thank you for the data reference. Can anyone identify a technical document reference for the JANAF data for air? I cannot seem to find it and I am uncomfortable citing a website in my paper.
Thanks in advance,
Daniel
immortality likes this.
dancfd is offline   Reply With Quote
Old   May 14, 2015, 08:13
Default how to caclculate/find the integration constants ?
  #39
Mieszko Młody
ziemowitzima is on a distinguished road
It seems that this question was not answered (but asked several times in the upper discussion).
Is anyone of you aware how the constants of integration are calculated ?
I know that:
H(T) = \int  Cp(T) \, dT + C1
S(T) = \int  \frac{Cp(T)}{T} \, dT + C2
but what is the value of C1 and C2, which is needed for JANAF as a6 and a7 ?
thanks
ZMM
ziemowitzima is offline   Reply With Quote
Old   February 4, 2016, 12:25
Default janaf explotes sprayfoam
  #40
Moritz
Momo1805 is on a distinguished road
Hello Foamers,
I am dealing with a similiar Problem concerning janafThermo out of Temp.-Range. I am injecting Propan at 1bar with T=300K with the sprayFoam solver. Mesh and boundaries are all the same as the tutorial. The first few timesteps run without problems but than my min temperature decreases within 2-3 timesteps resulting in values way underneath of 200K so my janafmodel explodes. Also I am using a boiling evaporation model as propan boils at around 240K.
Has anyone experienced the same or has any idea what I could change? Would be grateful for any help since I have no idea left. I enclose my log.file of the calculation.
Cheers Moritz
Momo1805 is offline   Reply With Quote
development, janaf, openfoam-1.5, thermophysicalproperties
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 07:19
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 16:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 11:27
