May 12, 2010, 11:51 |
OpenFOAm solver, ANSYS post processing
achinta
Rep Power: 16 |
I am new to OpenFOAM. I have good knowledge and experience with ANSYS. I am comparing performance of ANSYS and OpenFoam. So I am solving a problem in OpenFOAM and want to do postprocessing in ANSYS as I know it well. How can I convert OpenFoam results to ANSYS and do postprocessing in ANSYS? Is there any command? Thank you Cheers, Achinta |
May 13, 2010, 02:27 |
NAVEEN.K.M
Rep Power: 17 |
HI achinta;
foamDataToAnsys command is not available in OpenFOAM.you can convert foamDataToFluent and you can do the post processing in fluent. Regards, Naveen |
May 13, 2010, 03:37 |
achinta
Rep Power: 16 |
Hi Naveen,
I came to know that 'foamToCGNS' could be used to convert foam data and do post processing in ANSYS. But we have to download a setup file and the procedure is not clear. Any idea about this command ? Thank You, Achinta |
May 13, 2010, 03:54 |
NAVEEN.K.M
Rep Power: 17 |
HI achinta;
foamToCGNS converter only converts the mesh file without data which as been converted. you should search for foamDataToCGNS then you can use ansys for post processing. |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 11:58 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
Recommend software for simple post processing | zonexo | Main CFD Forum | 5 | March 4, 2006 04:20 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 12:59 |
