May 19, 2010, 11:04 |
#21 |
As you are using a steady-state solver, the timestep is not important. It is not a setting that will change the computation. Use "one" to correspond to the number of iteration
May 19, 2010, 11:32 |
#22 |
achinta
Rep Power: 16 |
Could I get a solution if I use k-omega sst model? Does any of the tutorials use this turbulence model? Thanks. Regards, Achinta |
May 19, 2010, 11:45 |
#23 |
Christian
Rep Power: 16 |
I think that changing your turbulence model will not fix your problem, you have to fix your checkMesh errors before playing with turbulence. Anyway, the motorBike tutorial use the kOmegaSST turbulence model. Regards Christian |
May 19, 2010, 11:51 |
#24 |
achinta
Rep Power: 16 |
I am working on mesh too. Thought I may get better results with k-omega sst model. motorbike tutorials is not running. somethings wrong. I found a strange thing in "$ HOME/OpenFOAM/usr-1.6/run/tutorials/incompressible/simpleFoam/motorBike/0/omega" FoamFile { version 2.0; format ascii; class volScalarField; object epsilon; } Is object epsilon?!! Please let me know if there are any other tutorials using k-omega sst model. Thanks Regards, Achinta |
May 20, 2010, 04:08 |
cyclic bc!
#25 | |
maddalena
Rep Power: 23 |
instead of using a wedge bc, you could try to use a cyclic bc. Wedge bc is usually used for a quasi 3D mesh (3D mesh one cell thick), while a cyclic bc is more suited for a real 3D case. Attention: the two faces creating the cyclic bc must be equal! Hope this help, cheers, mad |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
HELP! time step too small? | meangreen | Main CFD Forum | 6 | May 31, 2018 11:41 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 11:46 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 13:32 |
