May 10, 2010, 09:46 |
fluentMeshToFoam
achinta
Rep Power: 16 |
I am using 'fluentMeshToFoam' command to convert Fluent mesh(around 900 MB in size). Its taking a lot of time to convert(computer hangs). Is there a better option to convert the mesh in less time.
Thank you |
May 11, 2010, 02:30 |
achinta
Rep Power: 16 |
Hi Naveen,
1.Mesh is in ascii format. 2.I am using OpenFOAM-1.6 Regards, Achinta |
May 11, 2010, 02:51 |
santhosh
Rep Power: 17 |
Try Fluent3DMeshtoFoam,It is atest converter.
Regards Santhosh |
May 11, 2010, 02:53 |
fluentMeshToFoam
NAVEEN.K.M
Rep Power: 17 |
Dear achinta,
can you give more details regarding your problem. 1) whether it is 2D or 3D. 2) How many cells are there in your mesh. 3) What type of problem it is. Regards, Naveen |
May 11, 2010, 02:54 |
santhosh
Rep Power: 17 |
If dat doent work, run dos2unix command on the mesh file. It tries to remove any dos charactors from the mesh if is taken from widows machine..
Regards Santhosh |
May 11, 2010, 06:00 |
achinta
Rep Power: 16 |
Hi Santoo,
fluent3DMeshToFoam is working... Its fast for small mesh(300 MB size).. Its taking lot of time for 1.3 GB mesh.. Thank you |
May 11, 2010, 06:01 |
achinta
Rep Power: 16 |
Hi Naveen,
1.Its a 3D problem. 2.It has 4 million cells. 3.Its related to gas turbine combustion-steady state turbulence model Thanking You Achinta Last edited by achinta; May 11, 2010 at 10:32. |
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 05:56 |
[Commercial meshers] FluentMeshToFoam segmentation fault | gtg627e | OpenFOAM Meshing & Mesh Conversion | 6 | June 27, 2011 11:34 |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 17:56 |
[Commercial meshers] a probem with fluentMeshToFoam | wei_wu | OpenFOAM Meshing & Mesh Conversion | 3 | June 13, 2009 11:22 |
[Commercial meshers] Error fluentMeshToFoam | loneboard | OpenFOAM Meshing & Mesh Conversion | 26 | February 6, 2009 11:20 |
