wmake error in openFoam1.6 about randomperturbation |
May 6, 2010, 05:22 |
Rep Power: 16 |
dear freinds
hi i have a this problem about wmake of my randomperturbation data in openFoam1.6.do you have any experience about that?your help makes me happy. mohammad@mohammad:~/Desktop/initialize/RandomPertubration$ wmake g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/mohammad/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/mohammad/OpenFOAM/OpenFOAM-1.6/src/cfdTools/general/lnInclude -IlnInclude -I. -I/home/mohammad/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/mohammad/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linuxGccDPOpt/RandomPertubration.o -L/home/mohammad/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt \ -lfiniteVolume -lfoamUtil -lOpenFOAM -liberty -ldl -lm -o /home/mohammad/OpenFOAM/mohammad-1.6/applications/bin/linuxGccDPOpt/RandomPertubration /usr/bin/ld: cannot find -lfoamUtil collect2: ld returned 1 exit status make: *** [/home/mohammad/OpenFOAM/mohammad-1.6/applications/bin/linuxGccDPOpt/RandomPertubration] Error 1 |
May 7, 2010, 18:56 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings mrn,
After I did a little research, it seems that you are trying to use an old application for OpenFOAM with a more recent version. More specifically, your application was designed to work with a version prior to 1.4.1. My information came from the file OpenFOAM-1.4.1.General.gtgz, available here: OpenFOAM at sourceforge.net In its README file it states: Quote:
I searched for "RandomPertubration" online but I didn't find where you got it from, so I can only make estimations as to how you can fix the compiling problems. Best regards, Bruno
May 11, 2010, 02:06 |
re:wmake error
Rep Power: 16 |
dear wyldckat
hi thanks for your help.i did however you said.your guess exactly was true.and about random perturbation,this document is used to make random flow generation.it means that with this code and exe file for it we can make initial guess for our Les solution.we used it because our solution without random perturbation had tended to laminar characteristics of flow.of course my application has a two periodic B.C at stream wise and span wise directions. best regards |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 02:36 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 22:45 |
[OpenFOAM] ParaFoam error message | joey | ParaView | 1 | October 2, 2006 14:28 |
