interFoam more Axi-symmetric two phase flow ?
Old   April 30, 2010, 12:08
Default interFoam more Axi-symmetric two phase flow ?
Javier Basurco
Ingenierias2003 is on a distinguished road
Dear OpenFoam user's,
I am trying to setup a case in OpenFoam 1.6 for simulated a slug air - water two-phase flow in a micropipe but instead of a using all geometry; I trying to use an axi-symmetric approach. I build my mesh using a blockMesh in according to the UserGuidde.pdf from OpenFOAM using the wedge boundary for the front and back plane, still I am usage the setFields function to set a stratified flow to start the simulation.
Really, I don't know what's happend because my simulation stop suddenly after read p, U and alpha1 in the first step.
This is the message in the konsole:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-53b7f692aa41
Exec : interFoam
Date : Apr 30 2010
Time : 11:56:41
Host : javierbasurco-desktop
PID : 10345
Case : /home/javierbasurco/OpenFOAM/javierbasurco-1.6/run/tutorials/multiphase/interFoam/AxiSym2D_1
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading g
Reading field p
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
time step continuity errors : sum local = 1.816956462e+279, global = 1.816956462e+279, cumulative = 1.816956462e+279
DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.520219667e-11, No Iterations 333
time step continuity errors : sum local = 5.082309452e+270, global = 1.183822335e+268, cumulative = 1.816956462e+279
Courant Number mean: 9.800427968e-08 max: 1.018603267e-06
Starting time loop
Time = 1e-10
MULES: Solving for alpha1
Liquid phase volume fraction = -6.746125482e+276 Min(alpha1) = -5.096371243e+280 Max(alpha1) = 4.741194544e+271
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::multiply<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/interFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator*<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/interFoam"
#6 Foam::fv::gaussConvectionScheme<double>::flux(Foam ::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so"
#7 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fvc::flux<double>(Foam::GeometricField<doubl e, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/interFoam"
#8 main in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/interFoam"
#9 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#10 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/javierbasurco/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/interFoam"
Exception for flutuate point
Please, help me. I don't know where is the error or if is possible using interFoam with axi-symmetric mesh??? Also I post my case if anybody could be evaluate !!!
My deep regards
Respectfully
Ingenierias2003
Ingenierias2003 is offline   Reply With Quote
Old   April 30, 2010, 16:34
Eelco Gehring
feijooos is on a distinguished road
I would check your boundary conditions and mesh, see this line:
feijooos is offline   Reply With Quote
Old   May 10, 2010, 10:18
Javier Basurco
Dear Eelco Gehring,
Sorry but don't attend you, i retunr for a congress on multiphase flow. Do you revised my case and found any error in the implementation.
I look a forward to hearing from you!!
My deep regards
Respectfully
Ingenierias2003
Old   May 10, 2010, 12:15
Eelco Gehring
Sorry Javier, but you're going to have to look at the case by yourself for now. It is around that time where I am finishing up my thesis, so please check it out yourself and see if you can figure it out.
Old   May 10, 2010, 15:39
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Hi, Javier,
I revised your blockMesh. I did not check your BCs. I did not get the initial error you encountered.
after untar the case, run ./runCase. It will do blockMesh, setFields, and then, run interFoam.
Pei
phsieh2005 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Two phase flow with condensation Sunnie FLUENT 0 May 31, 2009 11:02
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 22:58
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 08:59
