Solve dS_dt + div(vect(U)*f(S))=q
Old   April 29, 2010, 12:46
Default Solve dS_dt + div(vect(U)*f(S))=q
andres
andresbh is on a distinguished road
Hi
I am trying to solve this equation in openfoam.
where f(S) is a known equation dependent of S. S cannot be explicitly extracted from f(S).
up to now if I implement the equation as stated above I get an error concerning calculatedFvPatchField.
Has anybody had similar problems?
Thanks
Andres
andresbh is offline   Reply With Quote
Old   April 30, 2010, 02:08
Alberto Passalacqua
A bit vague :-)
You should give some more detail on how the equation was implemented, and be specific with the error message.
Best,
Alberto Passalacqua
Old   April 30, 2010, 04:44
Default Impementaiton
andres
Hi Alberto,
I hope that the problem declaration this time is more illustrating.
Implementation:
The initial values of
volScalarField S
volVectorField U
are read from the case directory 0 and
dimensionedScalar const1
dimensionedScalar const2
from the constant directory.
The implementation reads
    volScalarField X = (S-const1)/(const2);
    f = pow(X,2)/(2*pow(X,2)-2*X-1);
    phi = linearInterpolate(U) & mesh.Sf();
    fvScalarMatrix SEqn
            por*fvm::ddt(S) +
            fvm::div(phi,f) ==
            q
        solve(SEqn);
Error:
--> FOAM FATAL ERROR:
    valueInternalCoeffs cannot be called for a calculatedFvPatchField
    on patch fixedWalls of field f in file "/home/i/andres/Simulations/FOAM/darcy2/0/f"
    You are probably trying to solve for a field with a default boundary condition.
    From function calculatedFvPatchField<Type>::valueInternalCoeffs(const tmp<scalarField>&) const
    in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 145.
I am no very sure what this means. Do I need to create my own boundary condition to fulfill this? or can I define my equation in another way ?
Thanks
Andres
Old   April 30, 2010, 04:57
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
try to replace
fvm::div(phi,f)
with
fvc::div(phi,f)
You cant solve implicitly for both f and S, they arent really the same fields are they?
niklas is offline   Reply With Quote
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 07:58
Using Compressible Solver (sonicFoam) to solve subsonic flows ezsoal OpenFOAM 0 October 27, 2009 10:13
Solve for two or more "Temperatures" Rui CFX 12 September 9, 2008 22:58
MAC method solve for pressure at boundry Ron Main CFD Forum 2 January 28, 2006 03:14
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 11:00
