April 28, 2010, 01:04 |
Rigid Body with 3-DOF rotation
Lv Peng
Rep Power: 17 |
I wonder whether I can apply inertial coordinates, instead of rotation axis and angular velocity, to describe the rigid body with 3-DOF rotation in OF. The inertial coordinates are transformated by a coordinate transition matrix form body-fixed coordinate system to inertial coordinate system. If it can, I should use which Foam? InterDyMFoam or MRFFoam? Best wishes peng |
April 28, 2010, 04:56 |
Masashi Ohbuchi
Rep Power: 17 |
Please refer a paper by Dr. Jasak.
http://powerlab.fsb.hr/ped/kturbo/Op...h_AIAA2009.pdf But detail setup procedure does not described in this paper. The appropriate solver is turbDyMFoam of OF-1.5-dev, I think. But I'm afraid you need some custom mesh changer class. |
April 28, 2010, 07:18 |
#3 | |
Lv Peng
Rep Power: 17 |
Thank you for your valuable suggestion. I must point that my study object involves a large scale mesh deformation. I want to simplify it depending on the whole field rotation and just get the near field details. Thank you again for your kind help. Best wishes Peng |
June 28, 2011, 05:43 |
Paul Bomke
Rep Power: 16 |
To be able to use 3D rotation you need to modify the mesh class.
In src/dynamicMesh/dynamicFvMesh/ you will find the mesh class mixerGgiFvMesh. Here, coordinates are defined in a cylindrical coordinate system, the coordinate system object cs which is initialized in the constructor method. If you delete those lines the whole thing will be specified in cartesian coordinates. Then you need to adjust the part where the mesh is moved, the update() method: Here it says: Code:
csPtr_->globalPosition movePoints ( csPtr_->localPosition(allPoints()) + vector(0, rpm_*360.0*time().deltaT().value()/60.0, 0) *movingPointsMask() ) - get the pointer to the coordinate system and convert all points of to local coordinates relative to the origin - add a vector which holds the values (radius, angle, height), thus all points of the mesh are rotated by rpm_*360.0*time().deltaT().value()/60.0 - apply a mask which holds a value of 0 or 1 for each point of the mesh. For rotor points the value is 1, for stator points it is 0. Thereby the motion is restricted to the rotor part. - the enclosing csPtr_->globalPosition transfers the points back to global coordinates. What you need here is a 3D rotation matrix instead. You already got rid of the cylindrical coordinates, so all you need to do next is something like: Code:
movePoints( (((allPoints() - origin) ^ rotationMatrix) - origin) * movingPointsMask; ); Ah, you also need to delete a "cs.()" somewhere around line 80 where it says: Code:
label originRegion = rs[findNearestCell(cs().origin())]; As a solver you can use anything that incorporates moving meshes, I think they all have a "DyM" in their name. Hope this helps a bit. Paul |
Rigid body | Birkov | CFX | 4 | May 25, 2012 07:26 |
Turbulent solver rigid body mechanics | philippose | OpenFOAM Running, Solving & CFD | 53 | July 16, 2011 14:35 |
Rigid body rotation NOT through the CG? | Joe | FLUENT | 6 | May 28, 2010 12:03 |
Rigid Body State Variables in Solid Immersed Simulation | Hamidreza | CFX | 1 | October 19, 2009 07:14 |
Rotation of a 3d rigid body through its free end | M-Ray | FLUENT | 0 | May 20, 2008 10:56 |
