April 27, 2010, 03:00 |
error when solving gamma equation?
jingjing
Rep Power: 17 |
Hi , I met floating exception error when using interDyMFoam solver to run my cases.
Surprisingly, this error didn't happen until recently. Previously, I just found the gamma values are not calculated well. Please see http://www.cfd-online.com/Forums/openfoam/73494-problem-about-max-gamma-1-a.html. After I improve the tolerance , that problem seems to be fixed. I run several cases well. I remember that I make no change recently. So why this error pops up? Please give me some hint about this problem. Thanks! Foam::error:rintStack(Foam::Ostream&) in "/home/jingjing/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/jingjing/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 void Foam::MULES::limiter<Foam:neField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam:neField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/home/jingjing/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #4 void Foam::MULES::explicitSolve<Foam:neField, Foam::zeroField, Foam::zeroField>(Foam:neField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/home/jingjing/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/home/jingjing/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #6 main in "/home/jingjing/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interDyMFoam" #7 __libc_start_main in "/lib64/libc.so.6" #8 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/jingjing/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interDyMFoam" |
April 27, 2010, 04:32 |
dilemma between accuracy and stability
jingjing
Rep Power: 17 |
If I decrease the tolerance, my case continue to run, but the previous problem that gamma value exceed 1 still exist.
So how to get accuracy on base of stability? As I am making numerical converge test for the wave generated in my wave tank, a proper accurate result should be needed in order to analyse wave dissipation due to viscous effect, on the base of eliminating numerical dissipation and dispersion effect. But I have no experience on numerical analysis. Any advise for improvement will be appreciated. my fvSchemes file: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(U) Gauss linear; grad(gamma) Gauss linear; } divSchemes { div(rho*phi,U) Gauss limitedLinearV 1; div(phi,gamma) Gauss vanLeer; div(phirb,gamma) Gauss interfaceCompression; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; pd; pcorr; gamma; } // ************************************************** *********************** // my fvSolution file: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { pcorr PCG { preconditioner DIC; tolerance 1e-7; relTol 0; }; pd PCG { preconditioner DIC; tolerance 1e-15; relTol 0; }; pdFinal PCG { preconditioner DIC; tolerance 1e-15; relTol 0; }; U PBiCG { preconditioner DILU; tolerance 1e-7; relTol 0; }; cellDisplacement PCG { preconditioner DIC; tolerance 1e-7; relTol 0; }; } PISO { momentumPredictor no; nCorrectors 2; nNonOrthogonalCorrectors 0; nGammaCorr 1; nGammaSubCycles 2; cGamma 1; pRefCell 0; pRefValue 0; } // ************************************************** *********************** // |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
