problems with a LES incompressible calculation (pisoFoam)
Old   April 20, 2010, 10:37
Default problems with a LES incompressible calculation (pisoFoam)
laurencep is on a distinguished road
I am a new user of openFoam.
I'm looking for information to carry out a non stationary calculation of turbulence under a hull of boat in LES.
I do not arrive has to initialize my calculation correctly because it diverges very quickly (Co number >> 1).
the result obtained on the pressure are wrong (-4.5e14 with 4.5e14)
I use the solver pisoFoam, with the model of turbulence dynamicSmagorinsky
is what somebody will be able to help?
thank you
laurencep is offline   Reply With Quote
Old   April 20, 2010, 10:44
Cedric Van Holsbeke
CedricVH is on a distinguished road
First try to decrease the time step in order to decrease the courant number. If this is not possible, then try using pimpleFoam instead of pisoFoam as this solver can iterate several times trough your U and p equations during one time step.
If the case still diverges, try using a different LES model such as OneEqEddy.
CedricVH is offline   Reply With Quote
Old   April 22, 2010, 05:53
thank you for your answer.
I have to try to decrease the step of time and to change the model. Calculation always diverges.
I have to test the model pimpleFoam (Smagorinsky and cubeRootVol delta) I obtain an error message at the end of about fifteen iterations.
Do you have an idea from what does not go?
thank you
error message :
[0] [1] ##0 0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)[3] #0 [2] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&) in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #2 in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #2 ?? in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #2 in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #2 ?? in "/lib64/tls/libc.so.6"
[1] #3 Foam::Time::adjustDeltaT()???? in "/lib64/tls/libc.so.6"
[0] #3 Foam::Time::adjustDeltaT() in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #4 in "/lib64/tls/libc.so.6"
[3] #3 Foam::Time::adjustDeltaT() in "/lib64/tls/libc.so.6"
[2] #3 Foam::Time::adjustDeltaT() in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #4 in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #4 in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #4 mainmainmainmain in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pimpleFoam"
[1] #5 __libc_start_main in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pimpleFoam"
[0] #5 __libc_start_main in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pimpleFoam"
[2] #5 __libc_start_main in "/home/users/applis/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pimpleFoam"
[3] #5 __libc_start_main in "/lib64/tls/libc.so.6"
[1] #6 in "/lib64/tls/libc.so.6"
[0] #6 in "/lib64/tls/libc.so.6"
[2] #6 in "/lib64/tls/libc.so.6"
[3] #6 _start_start_start_start at ../sysdeps/x86_64/elf/start.S:116
[node02:13104] *** Process received signal ***
[node02:13104] Signal: Floating point exception (8)
[node02:13104] Signal code: (-6)
[node02:13104] Failing at address: 0x1fa00003330
[node02:13104] [ 0] /lib64/tls/libc.so.6 [0x2a98178410]
[node02:13104] [ 1] /lib64/tls/libc.so.6(gsignal+0x3d) [0x2a9817837d]
[node02:13104] [ 2] /lib64/tls/libc.so.6 [0x2a98178410]
[node02:13104] [ 3] /home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2a974f73d9]
[node02:13104] [ 4] pimpleFoam [0x41656b]
[node02:13104] [ 5] /lib64/tls/libc.so.6(__libc_start_main+0xdb) [0x2a981664bb]
[node02:13104] [ 6] pimpleFoam [0x415759]
[node02:13104] *** End of error message ***
[node02:13103] *** Process received signal ***
[node02:13103] Signal: Floating point exception (8)
[node02:13103] Signal code: (-6)
[node02:13103] Failing at address: 0x1fa0000332f
[node02:13103] [ 0] /lib64/tls/libc.so.6 [0x2a98178410]
[node02:13103] [ 1] /lib64/tls/libc.so.6(gsignal+0x3d) [0x2a9817837d]
[node02:13103] [ 2] /lib64/tls/libc.so.6 [0x2a98178410]
[node02:13103] [ 3] /home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2a974f73d9]
[node02:13103] [ 4] pimpleFoam [0x41656b]
[node02:13103] [ 5] /lib64/tls/libc.so.6(__libc_start_main+0xdb) [0x2a981664bb]
[node02:13103] [ 6] pimpleFoam [0x415759]
[node02:13103] *** End of error message ***
[node01:13082] *** Process received signal ***
[node01:13082] Signal: Floating point exception (8)
[node01:13082] Signal code: (-6)
[node01:13082] Failing at address: 0x1fa0000331a
[node01:13082] [ 0] /lib64/tls/libc.so.6 [0x2a98178410]
[node01:13082] [ 1] /lib64/tls/libc.so.6(gsignal+0x3d) [0x2a9817837d]
[node01:13082] [ 2] /lib64/tls/libc.so.6 [0x2a98178410]
[node01:13082] [ 3] /home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2a974f73d9]
[node01:13082] [ 4] pimpleFoam [0x41656b]
[node01:13082] [ 5] /lib64/tls/libc.so.6(__libc_start_main+0xdb) [0x2a981664bb]
[node01:13082] [ 6] pimpleFoam [0x415759]
[node01:13082] *** End of error message ***
[node01:13083] *** Process received signal ***
[node01:13083] Signal: Floating point exception (8)
[node01:13083] Signal code: (-6)
[node01:13083] Failing at address: 0x1fa0000331b
[node01:13083] [ 0] /lib64/tls/libc.so.6 [0x2a98178410]
[node01:13083] [ 1] /lib64/tls/libc.so.6(gsignal+0x3d) [0x2a9817837d]
[node01:13083] [ 2] /lib64/tls/libc.so.6 [0x2a98178410]
[node01:13083] [ 3] /home/users/applis/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2a974f73d9]
[node01:13083] [ 4] pimpleFoam [0x41656b]
[node01:13083] [ 5] /lib64/tls/libc.so.6(__libc_start_main+0xdb) [0x2a981664bb]
[node01:13083] [ 6] pimpleFoam [0x415759]
[node01:13083] *** End of error message ***
Abt: the speed of sound in incompressible flows jinwon park Main CFD Forum 3 August 21, 2008 21:44
Basic LES question toyCFD Main CFD Forum 3 August 23, 2006 16:09
Using compressible BCs for incompressible problems cfd Main CFD Forum 1 April 16, 2006 03:41
problems with LES run Tim CFX 1 February 27, 2006 08:28
Implicit scheme for incompressible flow problems Triton Main CFD Forum 4 August 25, 2002 05:54
