Connect 2 Regions
Old   April 19, 2010, 07:18
Default Connect 2 Regions
Marc Redmer
Marc_r is on a distinguished road
Hallo everyone on CFD Online,
i'm quite new to OpenFOAM and having some problems to get a IcemCFD mesh to FOAM.
I want to have separated Regions to use with chtMultiRegionFoam.
The only way to get no errors on fluentToFoam is to split the internal faces in IcemCFD??
Then i get a good mesh with 2 or more separated Regions not connected by any faces. This can be split with splitMeshRegions. Now all patches/faces that shoud be linked have to be set manuely.
Is there a way to tell the mesh with 2 regions that the patch "Fluid_TO_SOLID" is linked with "SOLID_TO_FLUID"?
So that sheckMesh woud tell me something like: Mesh with 2 Region connected by ...?
greets Marc
Marc_r is offline   Reply With Quote
Old   April 19, 2010, 10:29
Marc Redmer
blockMesh has this option to merge faces or match fases with "mergePatchPairs" but i can't figure out how to use this on my existing mesh...?
Old   April 19, 2010, 14:27
Cyp
Cyprien
Cyp is on a distinguished road
To use mergePatchPairs, you need first to define your patches for example :
patches
    cyclic interface1
        (0 4 7 3)
    cyclic interface2
        (1 5 6 2)
Then, you can merge these patches with :
mergePatchPairs
    (interface1 interface2)
Is it what you ask for ?
Cyp is offline   Reply With Quote
chtmultiregionfoam, mesh, region
Separated Regions of Centrifugal Impeller Suzzn CFX 0 February 27, 2010 12:05
connect failed with errno%3d113 wedsall OpenFOAM Running, Solving & CFD 2 November 3, 2008 05:17
how to define different regions in icem ? Hammam CFX 3 July 9, 2007 13:56
connect the regions Lalitha Siemens 2 July 5, 2005 05:02
refinement causes composite regions, how to solve? Harry CFX 4 December 8, 2004 06:13
