Phase segregation in multiphaseInterFoam
Old   April 15, 2010, 09:42
Unhappy Phase segregation in multiphaseInterFoam
Søren
Tracker is on a distinguished road
Hey guys,
I have a problem. I'm currently simulating a 3 phase injectionmolding process in OpenFoam using multiphaseInterFoam, and the phases keep segregating. I have tried adjusting the sigmas in the transportProperties and the alphaContactAngle in my alphaair. How do i adjust the phases compatibility so they don't segregate so violently?
t=0
t=0.001
Tracker is offline   Reply With Quote
Old   April 15, 2010, 10:38
Claus Meister
idrama is on a distinguished road
Have yet tried to simulate without any contact angles, i.e. zeroGradient at all walls?
Furthermore, could you post transportProperties, U and p.
I would like to take a closer look
idrama is offline   Reply With Quote
Old   April 16, 2010, 07:52
Søren
Thanks for your reply!
I just tried that and it still goes zebra on me...
Here is the code. Some is from the damBreak4phase case. I also have at problem with floating point exception when I increase the viscosity of the binder or the powder.
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
    type            zeroGradient;
    left
        type            fixedValue;
        value           uniform 0;
    right
        type            fixedValue;
        value           uniform 0;
    defaultFaces
    type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
    type            fixedValue;
    value        uniform (0 -2 0);
    left
        type            zeroGradient;
    right
        type            zeroGradient;
    defaultFaces
        type            fixedValue;
        value           uniform (0 0 0);
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
phases          (
powder { transportModel Newtonian ;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-03 ;
rho rho [ 1 -3 0 0 0 0 0 ] 7800 ; }
binder { transportModel Newtonian ;
nu nu [ 0 2 -1 0 0 0 0 ] 0.1 ;
rho rho [ 1 -3 0 0 0 0 0 ] 1000 ; }
air   { transportModel Newtonian ;
nu nu [ 0 2 -1 0 0 0 0 ] 1.48e-03 ;
rho rho [ 1 -3 0 0 0 0 0 ] 1 ; } );
refPhase        air;
sigmas          ( ( air binder ) 0 ( air powder ) 0 ( binder powder ) 0 );
Old   May 7, 2010, 05:10
Default Immiscible phases...
Søren
Apparently I have missed that multiphaseInterFoams phases are immiscible. So this solver can't be used to simulate segregation in metal injection moulding.
multiphaseinterfoam
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 08:11
Specifying phase on both sides of a Boundary Condition? rassilon OpenFOAM Running, Solving & CFD 3 November 11, 2009 01:41
Help Regarding Segregation Model in FLOW-3D Pathak FLOW-3D 0 April 5, 2009 11:25
Source Term used in Eulerian Model(Two phase) Padian FLUENT 1 May 19, 2008 04:47
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
