axisymmetric geometry within engineFoam
Old   April 13, 2010, 15:21
Default axisymmetric geometry within engineFoam
Antonella
antonellaP is on a distinguished road
hello everyone,
I am a beginner with OpenFoam and specifically I have some problems with the engineFoam.
I'm trying to set up an axi-symmetric geometry in order to simulate (employing the wedge patch type) just a few degrees slice of the combustion chamber instead of the entire cylinder geometry.
The problem I encounter is that the code seems to necessarily require the piston motion to be alligned with the z-axis and at the same time that the symmetry axis (when the wedge patch type is used) must be the x-axis.
This makes impossible to set-up my case, since the symmetry axis (which is, of course, the cylinder axis) and the piston motion direction in the considered geometry should be the same.
Has someone else encountered the same issue? Do you know if any kind of solution has been found?
I would be very grateful of any help you can give me.
Thank you
antonellaP is offline   Reply With Quote
Old   April 14, 2010, 14:58
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Are you sure? Where did you get this information?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 14, 2010, 16:16
Antonella
hello, tanks for your reply,
I'm not exactly sure, but, since I was having problems with this geometry, I had a look on the web and on this url: http://openfoamwiki.net/index.php/Si...nical_diffuser
at section 1.6 Case1.3: Case1 as a 2D wedge case
I have read: "This case is similar to Case1, but the simulation is now done in 2D using a wedge geometry (2D radial mesh) and wedge boundary conditions. OpenFOAM requires such geometries to have the symmetry axis along the x-axis, so Case1.3 is transformed to use the x-axis as the main flow direction instead of the z-axis."
Do you have different information or advice? Have you solved similar problems successfully?
Thanks a lot for your help
Old   April 15, 2010, 07:59
sega's Avatar
Sebastian Gatzka
I wasn't aware that wedge cases are that restrictive!?
Any comments from the pros?
Old   August 30, 2012, 05:55
akidess's Avatar
Anton Kidess
Old thread, but worth adding I don't think this is true. See http://www.openfoam.org/docs/user/bo...hp#x24-1390014, figure 5.4 and table 5.1.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
shear stress in axisymmetric geometry antonio_ing OpenFOAM Running, Solving & CFD 0 May 27, 2009 08:24
interDyMFoam for axisymmetric geometry antonio_ing OpenFOAM Running, Solving & CFD 2 May 26, 2009 15:57
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Meshing axisymmetric geometry Prachi CFX 4 May 23, 2006 05:46
