Problems with icoDyMFoam
Old   April 13, 2010, 13:56
Default Problems with icoDyMFoam
Patrick Mueller
PaMuelle is on a distinguished road
Hi!
As some of you might recall, I am currently writing an exam about OpenFoam at my university.
Until now, I managed to set up and solve all the cases I need with MRFSimpleFoam. But now, I want to solve the same cases with icoDyMFoam, and I am just stuck.
I started with the Wiki example (http://openfoamwiki.net/index.php/MRFSimpleFoam).
I set up the mesh like it's done in the tuturial (with the needed modifications for ggi) and then transferred it to OpenFoam.
1. fluent3DmeshToFoam
2. faceSet + setsToZones - noFlipMap (to create both zones for ggi)
checkMesh (incl. -allTopology and -allGeometry) didn't show any errors.
To get the needed files, I used the files from the mixerggi tutorial case.
Now I started simulating, and every time my simulation stops at t=0.05.
It doesn't matter what timestep or rpm I use, it always stops at 0.05.
I also set up the case with turbDyMFoam and it stops at t=0.05, too.
Furthermore, I looked at the output in paraView, and it looks good, I don't see any reason why it shouldn't work.
I'm using OF1.5-dev. The tutorial cases worked just fine.
I will attach the logfile and controlDict. If you need anything more, just ask, I'll add it as soon as I can.
I really hope anybody sees some error I don't see and can help me, I would really appreciate it!
Regards,
PaMuelle
Logfile
PaMuelle is offline   Reply With Quote
Old   April 20, 2010, 10:21
Patrick Mueller
I know, pushing my own thread sucks. But does no one have a clue? This project is really important to me and solving this problem would mean a lot. Even small hints about what I should try would help
Old   April 21, 2010, 07:56
David Boger
boger is on a distinguished road
Do you get any error messages from the code? Or it simply stops? Can you post the screen output?
David A. Boger
boger is offline   Reply With Quote
Old   April 21, 2010, 07:58
Patrick Mueller
I attached the Logfile (it's too large to upload here, therefore it's hosted at rapidshare). That's the whole output I get. No segmentation fault or anything else.
Old   April 21, 2010, 08:23
David Boger
Sorry, I missed the log the first time. Sorry, too, that I have no ideas for you. It looks like it stops in the middle of the run loop, so I don't understand why it wouldn't emit some kind of error message somewhere. What variations did you try for the time step and RPM? Could you run the code from a bourne shell and separate stdout from stderr? e.g.
#!/bin/sh
icoDyMFoam 1> out.log 2> err.log
David A. Boger
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 13:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
IcoDyMFoam and tetrahedral meshes ulrich_lange OpenFOAM Running, Solving & CFD 11 April 16, 2007 17:44
Some problems with Star CD Micha Siemens 0 August 6, 2003 14:55
Using Fluent for Geophysical Problems Hassid Samuel FLUENT 0 February 23, 2001 07:04
