wallShearStress & creatTurbulenceFields in OF 1.6
Old   April 12, 2010, 08:05
Question wallShearStress & creatTurbulenceFields in OF 1.6
alireza
ar_mofidi is on a distinguished road
I have a turbulent channel flow with slip BC. on bottom wall and I have solved this channel with channelFoam. I would like to calculate the WallShearStress and also I want to create turbulence fields for calculating the Reynolds stress R, in OpenFoam 1.6. I should be remind that my Turbulence Model is LES. How can I do that?
Regards,
Alireza
ar_mofidi is offline   Reply With Quote
Old   April 12, 2010, 12:14
Claus Meister
idrama is on a distinguished road
Have ya already try the post-processing tool wallShearStress ?
idrama is offline   Reply With Quote
Old   April 13, 2010, 04:31
alireza
Hi idrama
yes, I have used wallShearStress but it didn't work. when I use this term this message appears:
Create time
Create mesh for time = 3.00141
Time = 3.00141
Reading field U
Selecting incompressible transport model Newtonian
cannot open file
file: /home/sekhavat/OpenFOAM/sekhavat-1.6/run/tutorials/incompressible/channelFoamslip/channeltopwallslip/constant/RASProperties at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
Old   April 15, 2010, 04:39
Claus Meister
Hallo,
wallShearStress is dependent on on turbulence models, hence is need RASProperties. You must check that. Strangely, the time mesh value 3.**.
If you cannot fix it, check the Forum for "computing wall shear stresses", I think. In this Forum, there are already hot discussens about that.
cheers
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 10:53
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 01:48
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 raagh77 OpenFOAM Running, Solving & CFD 0 March 6, 2010 06:11
kOmegaSST in openfoam 1.6 Gearb0x OpenFOAM 2 March 3, 2010 07:02
utility utilization in 1.6 ! smm1457 OpenFOAM Running, Solving & CFD 3 January 17, 2010 16:06
