Wall boundary is ignored when using wedge
Old   April 7, 2010, 06:58
Default Wall boundary is ignored when using wedge
Wedge is on a distinguished road
I have build a nozzle using the wedge method.
It also looks like it is supposed to.
But when I run the case and view it in paraview it looks like the wall boundary gets ignored.
I am not sure if it is a visualization problem or if also openfoam ignores it. It seems to happen everytime I use wedge for creating cases.
If I use a tinier grid at the wall the velocity goes down but it doesn reach zero.
Maybe someone of you knows this situation and can help.problem
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
    ( -200.00   299.71    13.09) //  0 inlet top 1
    ( -200.00   299.71   -13.09) //  1 inlet top 2
    ( -200.00     0.00     0.00) //  2 tip
    (    0.00   299.71    13.09) //  3 nozzle inlet top 1
    (    0.00   299.71   -13.09) //  4 nozzle inlet top 2
    (    0.00     0.00     0.00) //  5 tip
    (  660.00    94.91     4.14) //  6 nozzle outlet top 1
    (  660.00    94.91    -4.14) //  7 nozzle outlet top 2
    (  660.00     0.00     0.00) //  8 tip
    ( 1000.00    94.91     4.14) //  9 outlet top 1
    ( 1000.00    94.91    -4.14) // 10 outlet top 2
    ( 1000.00     0.00     0.00) // 11 tip
edges
blocks
    //before nozzle
    hex (2 5 4 1 2 5 3 0) (15 20 1) simpleGrading (1 0.1 1)
    //nozzle
    hex (5 8 7 4 5 8 6 3) (73 20 1) simpleGrading (0.3333 0.1 1)
    //after nozzle
    hex (8 11 10 7 8 11 9 6) (70 20 1) simpleGrading (1 0.1 1)
patches
    wall SURF_WALL
        (0 3 4 1)
        (3 6 7 4)
        (6 9 10 7)
    symmetryPlane AXIS
        (2 5 5 2)
        (5 8 8 5)
        (8 11 11 8)
    patch SURF_INFLOW
        (2 2 1 0)
    patch SURF_OUTFLOW
        (11 11 9 10)
    wedge SURF_BACK
        (2 1 4 5)
        (5 4 7 8)
        (8 7 10 11)
    wedge SURF_FRONT
        (2 5 3 0)
        (5 8 6 3)
        (8 11 9 6)
mergePatchPairs
|  \\    /   O peration     | Version:  1.6                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    SURF_INFLOW
        type            fixedValue;
        value           uniform (50 0 0);
    SURF_OUTFLOW
    type        zeroGradient;
    SURF_WALL
        type            fixedValue;
        value           uniform (0 0 0);
    SURF_FRONT
        type            wedge;
    SURF_BACK
        type            wedge;
    AXIS
        type            symmetryPlane;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    SURF_INFLOW
        type            zeroGradient;
    SURF_OUTFLOW
        type            fixedValue;
        value           uniform 0;
    SURF_WALL
        type            zeroGradient;
    SURF_FRONT
        type            wedge;
    SURF_BACK
        type            wedge;
    AXIS
        type            symmetryPlane;
Wedge is offline   Reply With Quote
Old   February 7, 2011, 07:20
Default same problem
noramat is on a distinguished road
hello, i have exactly the same problem. Did you already find a solution? Thanks noramat
noramat is offline   Reply With Quote
isothermal wall boundary condition Neil Main CFD Forum 3 November 9, 2015 03:34
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
moving and slip wall boundary hongchun FLUENT 4 July 9, 2010 12:29
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Wall Boundary Condition in k - epsilon model abhijeet vaidya Main CFD Forum 0 July 14, 2002 04:18
