simpleFoam convergence on large domain
Like Tree1Likes
Old   May 15, 2011, 05:04
Alberto Passalacqua
Originally Posted by maysmech View Post
Dear Alberto,
I have problem with LRR for hydrocyclone simulation yet. i used your suggested settings, it doesn't diverge but nor converge.
As you see in attached picture LRR result is not converge and it has wild fluctuations across its mean. i have set dynamic smagorinsky results (its figure is attached) as initial for LRR but after ten days and 14000 iterates its result is not acceptable and it decays initial too. its mesh is fine (1000000) and i don't think grids be the problem because LES answered proper results with same mesh. i have attached settings too.
Any idea would be appreciated.
Regards,
Maysam
since the LES captures the flow properly, and it is an unsteady simulation (I assume you averaged the results in time), probably the steady solution is not representing the system properly (the flow in a cyclone is not strictly steady). You could try to run LRR in unsteady mode with pisoFoam to remove this doubt.
Best,
Alberto
Alberto Passalacqua
Old   May 22, 2011, 21:29
Smile
  #42
maysmech's Avatar
maysmech is on a distinguished road
Originally Posted by alberto View Post
Best,
Alberto
Dear Alberto,
I switched LRR from simpleFoam to pisoFoam.
It is strange for me but it gives good results with pisoFoam.
Thanks for your suggestion.
maysmech is offline   Reply With Quote
Old   May 22, 2011, 22:23
Alberto Passalacqua
Dear Alberto,
Good! This confirms that the flow is not steady, and you need to resolve it in time, which is not possible with simpleFoam. If possible, try to make a movie of the flow: you will probably notice that, even after a long time, it never reaches a fully steady condition.
Best,
Alberto Passalacqua
Old   May 31, 2013, 11:10
s.m
saeideh mohamadi
s.m is on a distinguished road
Originally Posted by askjak View Post
I would suggest to run a couple of hundreds of steps without turbulence (set "turbulence" to "off" in constant/RASProperties). Then turn it "on" while the simulation is running.
If it does not initial converge without turbulence generate an initial field from "potentialFoam -writep"
-Ask
hi askjak
would you please explain more, that how could generate an initial field from potentialFoam?
thank you very much
s.m is offline   Reply With Quote
Suggested unsteady, implicit solver stable with arbitrarily large time steps djbungee OpenFOAM Programming & Development 45 March 23, 2015 05:14
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 07:27
[Domain]Three different Domain Young CFX 3 April 27, 2008 15:11
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
Diverging wall scale due to large domain size Kevin CFX 3 November 12, 2006 16:48
