access to velocity gradient for Lagrangian particles |
April 20, 2010, 20:50 |
#21 | |
Jie
Rep Power: 16 |
I updated gradU every time step as I have gradU in the data set for each time step. However, the there is no gradU stored in the lagrangian folder. As I have the position data and gradU field data, I want to use the particle position information to check the gradU stored in the lagrangain particle is correct. |
April 21, 2010, 00:05 |
#22 |
Hi Jie
I cannot quite following you. Do you want to store the gradU at particle centers into the Lagrangian folder or gradU has been stored but the data was not correct. If they was not stored, just add a new variable for your particle class and add this IO utility for it like other properties in particle class. The IO utility is implemented in the following function 1) constructor function like this Foam::solidparticle::solidparticle ( const Cloud<solidparticle>& cloud, Istream& is, bool readFields ) 2) readFields 3) writeFields 4) operator<< If gradU has been written into lagrangian folder but not correct. I think they are not updated. Note that the volTensorField gradU you declare in your createFields.H is not the field of gradU in particle center. The first is the gradU in the patchcenters and cellCenters, whereas the second is the gradu in several discrete points. regards, Junwei |
April 21, 2010, 00:49 |
#23 |
Jie
Rep Power: 16 |
Hi JunWei
Sorry about the confusion. I tried to store the gradU at particle centers into the Lagrangian folder, but it only contains the fist particle. I added the following lines in the constructor: ###################################### Foam::solidParticle::solidParticle ( const Cloud<solidParticle>& cloud, Istream& is, bool readFields ) : Particle<solidParticle>(cloud, is, readFields) { if (readFields) { if (is.format() == IOstream::ASCII) { d_ = readScalar(is); is >> U_; //- ** velocity gradients is >> gradU_; } else { is.read ( reinterpret_cast<char*>(&d_), //sizeof(d_) + sizeof(U_) //- **velocity gradients sizeof(d_) + sizeof(U_) + sizeof(gradU_) ); } } // Check state of Istream is.check("solidParticle::solidParticle(Istream&)") ; } ##################################### and I asked it to write out the gradU #################################### void Foam::solidParticle::writeFields(const Cloud<solidParticle>& c) { Particle<solidParticle>::writeFields(c); label np = c.size(); IOField<scalar> d(c.fieldIOobject("d", IOobject::NO_READ), np); IOField<vector> U(c.fieldIOobject("U", IOobject::NO_READ), np); //- **velocity gradients IOField<tensor> gradU(c.fieldIOobject("gradU", IOobject::NO_READ), np); label i = 0; forAllConstIter(Cloud<solidParticle>, c, iter) { const solidParticle& p = iter(); d[i] = p.d_; U[i] = p.U_; //- **velocity gradients gradU[i] = p.gradU_; i++; } d.write(); U.write(); //- **velocity gradients gradU.write(); } #################################### in the lagrangain folder, gradU only contains: FoamFile { version 2.0; format ascii; class tensorField; location "101.3"; object gradU; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 1301{(0 0 0 0 0 0 0 0 0)} // ************************************************** *********************** // Instead of having all zeros in 1301{(0 0 0 0 0 0 0 0 0 0)}, it should have the gradU for all 1301 particles. I have no problem with U. |
April 21, 2010, 02:19 |
#24 |
Jie
Rep Power: 16 |
Hi JunWei
I have attached my solidparticleIO.C here. It looks like it counts the number of particles in the gradU in lagrangian folder, but all the gradU for each particle is not there. Last edited by jiejie; April 22, 2010 at 21:22. |
April 21, 2010, 06:02 |
#25 |
Hi Jie
1301{(0 0 0 0 0 0 0 0 0 0)} means there are 1301 particles with the same value. tensor::zero. The possible reason is that the gradU of the particle location was not updated. The attachment you provided is right I think. Regards, Junwei |
April 22, 2010, 21:27 |
#26 |
Jie
Rep Power: 16 |
Hi JunWei
I am still looking at how to update the gradU for each of the particle and I came across couple question as follows: 1. if gradU has 1301{(0 0 0 0 0 0 0 0 0 0)} at each time step, it means all the gradU stored in the particles are zero? 2. In the particle.C: template<class ParticleType> 00411 void Foam::Particle<ParticleType>::transformPosition(const tensor& T) 00412 { 00413 position_ = transform(T, position_); 00414 } It says this transforms the physical properties of the particle. But in parcel.C void Foam:: parcel::transformProperties(const tensor& T) 00689 { 00690 U_ = transform(T, U_); 00691 } It says this transforms the position and physical properties of the particle. How come it uses the velocity U_ to transform the position of the particle and it use position_ to transform the position of the particle? Thank you very much. Last edited by jiejie; April 22, 2010 at 23:55. |
April 24, 2010, 05:19 |
#27 |
1) if gradU has 1301{(0 0 0 0 0 0 0 0 0 0)} at each time step, it means all the gradU stored in the particles are zero?
Yes 2) transform can be used in rotation. T is rotational tensor. Junwei |
April 27, 2010, 02:39 |
#28 |
Jie
Rep Power: 16 |
figuring out how to update gradU.
Thanks for your time JunWei Last edited by jiejie; April 28, 2010 at 03:30. |
May 10, 2010, 04:01 |
#29 |
Jie
Rep Power: 16 |
One quick question: if I need to do an inner product of a tensor "T" and a vector "a", should it be "T & a" instead of "a & T"?
December 13, 2010, 15:34 |
How to find gradU from tauMC
#30 |
Ehsan
Rep Power: 17 |
Dear All,
tauMC is calculated via: volTensorField tauMC("tauMC",mu*dev2(fvc::grad(U)().T())); Could someonhe help me to find gard(U) from tauMC (revers of above relation) the notation gard(U)=tauMC/mu gives error. Thanks |
January 26, 2011, 11:57 |
Further variables in lagrangian folder
#31 |
Franco Marra
Rep Power: 17 |
Dear All,
After running dieselFoam, I would be like to observe further properties of the lagrangian field, as the Weber number of each particle, similarly to the way the diameter d or the density rho of each particle is reported in the lagrangian folder at each time step. However I am a newbe with C++ and I do not understand how I can adopt the function We available in the parcelFunctions.C to compute and store this quantity for each particle. Is this a simple task or does it require a long coding effort ? Any help will be very gratefully appreciated. Thank you in advance, Franco |
December 2, 2016, 05:56 |
#32 | |
Rep Power: 10 |
Dear Su Jun Wei,
I was trying to use your way to calculate the velocity gradient tensor. It works fine with one core. But error comes for parallel computing when try to access fvc::grad(). Do you have any idea? Best, ycui Quote:
Finely dispersed particles in predetermined velocity field | BrainDebugger | STAR-CCM+ | 1 | May 14, 2014 07:32 |
Velocity gradient on Symmetry Boundary | prikeyma | FLUENT | 2 | September 2, 2011 07:16 |
axial velocity in bend pipe with adverse pressure gradient | liguifan | OpenFOAM | 0 | July 24, 2011 06:56 |
Velocity gradient | Stephen | Main CFD Forum | 0 | April 7, 2003 11:28 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
