October 30, 2010, 14:25 |
#21 |
Marco A. Turcios
Rep Power: 28 |
Thanks Bruno. FoamToVTK is a little impractical with the setup I have going. After a little more digging, I found that it depends on the data fields I have loaded, some of which aren't calculated for all time steps. Therefore it seems like a plug-in bug.
Has anyone else used the vanilla ParaView 3.8.1 with OF 1.6, and if so what adjustments or tweaks have you had to make for it to work seamlessly? I like the stability of 3.8.1 in general and would like to use it as the default. |
October 31, 2010, 02:28 |
#22 | |
Takuya OSHIMA
Rep Power: 20 |
Hi Marco and Bruno,
@Marco: I see the problem with PV 3.8.1 (and only with 3.8.1, but not with 3.8.0 nor 3.9.0) too with a minor difference being I always see the problem regardless of what field I load. If we are discussing the same problem nonetheless, Merge Blocks should work. @Bruno: Quote:
#28 0x00007ffff7b59e9d in pqSelectionInspectorPanel::updateSelectionGUI() () Code:
commit 9cd0f355d03600e97b9b082dee0fa73ec62c4cac Date: Thu May 20 15:09:22 2010 -0400 BUG: Fixed a endless loop bug with multiblock data. Takuya |
October 31, 2010, 09:29 |
#23 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Takuya,
My apologies to you Takuya, for not fully thinking it through. Best regards, Bruno
OpenFOAM 1.6 and ThirdParty Software Paraview | dunlopjp | OpenFOAM Installation | 0 | February 24, 2010 12:35 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 13:59 |
[OpenFOAM] Animating Lagrangian Particles in ParaView | xiao | ParaView | 4 | April 8, 2008 03:24 |
[OpenFOAM] ParaView patch visualisation error in Development version | philippose | ParaView | 17 | March 26, 2007 07:45 |
