Slip BC not working properly
Old   March 26, 2010, 14:06
Exclamation Slip BC not working properly
Fran
lfbarcelo is on a distinguished road
Running the cavity case with icoFoam, I changed the boundary condition for the fixedWalls patch from fixedValue to slip, changing also the boundary file from wall to patch. I did this in order to test the slip BC in a simple case.
The result was not what I had expected. The side walls defined as slip walls, when visualized with paraFoam, show velocity in the X direction (normal to the patch). This should not happen acording to the definition of the condition "slip" given by OpenFOAM.
"Slip: zeroGradient if is a scalar; if is a vector, normal component is fixedValue zero, tangential components are zeroGradient"
Has anyone else had problems with this condition? Is it an OpenFOAM bug, or am I just missunderstanding what slip BC should do? Maybe I am missing some additional setting in order to make slip condition work.
Pressure condition is zeroGradient as in the original icoFoam/cavity case.
Thank you.
lfbarcelo is offline   Reply With Quote
Old   March 27, 2010, 12:30
Andrea Pasquali
andrea.pasquali is on a distinguished road
Also p, k and epsilon are slip.
You can check the motorbike tutorial.
regards
Andrea
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   June 21, 2010, 04:47
Smile slip boundary condition
王国斌
wangguobin14 is on a distinguished road
Send a message via ICQ to wangguobin14 Send a message via MSN to wangguobin14
Recently ,i do a lot of subjects on 'slip boundary condition',
some theoretically work have done, next step is how to implement in a soft ,which could deal with slip boundary conditon ,
thank you for your sharing that successful case!
thank you !
wangguobin14 is offline   Reply With Quote
Old   July 15, 2010, 10:53
Default ParaFOAM
Michael B Martell Jr
theory37 is on a distinguished road
This is simply a paraFoam artifact. Change the rendering mode and you will see those X velocities disappear.
theory37 is offline   Reply With Quote
boundary conditions, slip
MultiComponenMixturecellMixture not working properly dominik_christ OpenFOAM Running, Solving & CFD 1 August 6, 2008 05:25
Low-Pressure Boundary Slip AlexA FLUENT 1 January 5, 2007 22:30
Free slip and no slip. Yung Fidelity CFD 2 August 16, 2006 10:24
Free slip and no slip. Yung Phoenics 3 March 2, 2006 12:04
Free slip and no slip. yung FLUENT 0 February 4, 2006 11:26
