continue LES simulation after it stopped
Old   March 26, 2010, 10:16
Default continue LES simulation after it stopped
holand_us is on a distinguished road
Am a new OpenFOAM user
Am runing LES simulation with 10,000 time step
my problem is my walltime exceeded after 12 hours, and then I need to start from the begining,
Is there a way to continue my simulation from where it stopped
best
holand_us is offline   Reply With Quote
Old   March 26, 2010, 10:20
guillaume maurice
guillaumem is on a distinguished road
hi
i usualy copy the field in the field 0 and i restart the calculation you can also modify the starttime in the controlDict file
good luck for your calculation
guillaumem is offline   Reply With Quote
Old   March 26, 2010, 22:52
Pavan
rieuk is on a distinguished road
chenge the startTime entry in controlDict to latestTime
rieuk is offline   Reply With Quote
Old   March 27, 2010, 13:02
Piotr Prusinski
piprus is on a distinguished road
This is not entirely true, cause it will work only in the case when startFrom keyword is set to startTime.
Normally I'm using following configuration:
startFrom       latestTime;
startTime       0;
but this means I don't really need startTime at all. It's up to you which one is better, both are working fine to me.
piprus is offline   Reply With Quote
Old   March 27, 2010, 13:30
thanks allot ill try it on Monday and come to you guys
Old   March 30, 2010, 11:19
Hi it didnt work
when I continue the program let say after 5 hours, it write from the beginning on the probes/0/p, not continue from the last time field
HTML Code:
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pisoFoam;
startTime       0;
stopAt          endTime;
endTime         1e-03 ;
deltaT          1e-05;
writeControl    timeStep;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  12;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
functions
    probes
        type            probes;
        functionObjectLibs ("libsampling.so");
        enabled         true;
        outputControl   timeStep;
        outputInterval  1;
        probeLocations
            ( 0.0254 0.0253 0 )
            ( 0.0508 0.0253 0 )
            ( 0.0762 0.0253 0 )
            ( 0.1016 0.0253 0 )
            ( 0.127 0.0253 0 )
            ( 0.1524 0.0253 0 )
            ( 0.1778 0.0253 0 )
        fields
            p
    fieldAverage1
        type            fieldAverage;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        outputControl   outputTime;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
            p
                mean        on;
                prime2Mean  on;
                base        time;
Old   March 30, 2010, 11:23
Piotr Prusinski
Is this problem concerns only p or U either?
I have no experience with functions in OF yet, but have that feeling like it has to do something with the outputControl. Look that you are using different statements in probes and fieldAverage1.
I might be wrong, so help from other more advanced users would be here appreciated
Old   April 5, 2010, 11:14
mmm
I really didnt understand
But I still have the same problem
Old   April 5, 2010, 11:35
Piotr Prusinski
Sorry, maybe I didn't make myself clear enough. I was just wondering why you're using different values in case of outputControl keyword here:
    probes
and here:
    fieldAverage1
Is there any specific reason for doing like that?
I found something interesting >>here<<
Old   April 5, 2010, 13:52
Actually I dont know
i just copied paste the constDict from the
~/tutorials/incompressible/pisoFoam/les/pitzDaily
continue LES simulation after it stopped holand_us OpenFOAM Running, Solving & CFD 1 March 29, 2010 04:50
Restarting simulation on where it had stopped ulisses OpenFOAM 13 June 10, 2009 08:23
LES simulation of bluff body at Re(d)=1200 arash_nl FLUENT 0 June 1, 2009 14:16
LES simulation of sonic jet Jianping Main CFD Forum 0 January 21, 2005 06:52
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
