Face merging, patch definition, wall function |
March 24, 2010, 07:07 |
Rep Power: 16 |
Hello foamers,
I have a problem using blockMesh: I want to attach a cylinder face to a bigger rectangular block face using the command "mergePatchPairs". The goal is, that the cylinder face is completely merged to the block face, whereas the remaining block face should become a wall with wall functions applied. That's my question: How should I define the patches and boundary conditions? I already tried it, but it did not work. That's how I defined everything: File "blockMeshDict": patches ( patch cylinderface ( (1 2 3 4) ) wall blockface ( (5 6 7 8) ) ); mergePatchPairs ( (cylinderface bottomface) ); Boundary file 0/epsilon (i.e.): boundaryField { bottomface { type epsilonWallFunction; value uniform 0.000765; } } I got the following error: "Invalid wall function specification Patch type for patch bottomface must be wall Current patch type is patch" What does it mean? I defined the block face as a wall! Can anybody help me with this? Thanks, Stephan |
March 24, 2010, 12:17 |
Piotr Prusinski
Rep Power: 17 |
The only one thing I can't understand here is how could you merge the bottomface to anything, without specifing it in a patch list?
March 24, 2010, 12:48 |
Rep Power: 16 |
The patches are defined in the blockMeshDict file.
I solved the problem by deleting and recreating the boundary file. No everything works well :-) |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 19:25 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 13:23 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
