Setup for verticalValves
Old   March 23, 2010, 11:29
Default Setup for verticalValves
Peter_600 is on a distinguished road
Does anyone of you has experience with the class engineTopoChangerMesh?
I try to run a test case with a moving piston and one vertical valve.
I am using OF-1.5-dev.
I am struggling with the engnineGeometrie file with the liftProfile.
Hope someone of u can explain me or show how to set up the case!
regards
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object engineGeometry;
//engineMesh layered;
conRodLength conRodLength [0 1 0 0 0 0 0] 0.147;
bore bore [0 1 0 0 0 0 0] 0.092;
stroke stroke [0 1 0 0 0 0 0] 0.08423;
clearance clearance [0 1 0 0 0 0 0] 0.00115;
rpm rpm [0 0 -1 0 0 0 0] 1500;
deformAngle 10;
valvePosTol 1e-04;
delta 0.0005;
offSet 0.002;
checkMesh on;
engineTopoChangerMesh verticalValves;
piston
patch piston;
// patch none;
coordinateSystem
type cartesian;
origin (0 0 -0.09);
axis (0 0 1);
direction (0 1 0);
minLayer 0.002;
maxLayer 0.0025;
valveSplitPoint (0 0 0);
verticalValves
valve
// Valve coordinate system
coordinateSystem
type cylindrical;
origin (0.02 0 0.12);
axis (0 0 1);
direction (0 1 0);
// Patch and zone names
bottomPatch valveBottomIn;
poppetPatch valveTopIn;
stemPatch valveStem;
curtainInPortPatch ValveCurtainPortIn;
curtainInCylinderPatch ValveCurtainCylIn;
detachInCylinderPatch valveDetachCyl1;
detachInPortPatch valveDetachPort1;
detachFaces 5 (364 366 368 370 371);
// Vertex on edge of the step. For the converter
stemEdge (0.023 0.003 0.12);
// Valve diameter
diameter 0.028;
// Minimum valve lift
minLift 0.00025;
// Layer thickness
minTopLayer 0.0007;
maxTopLayer 0.0025;
minBottomLayer 0.005;
maxBottomLayer 0.01;
liftProfile
-540 0.01
My output from openFoam
| \\ / O peration | Version: 1.5-dev |
| \\ / A nd | Revision: exported |
| \\/ M anipulation | Web: http://www.OpenFOAM.org |
Exec : dieselEngineFoamLayer
Date : Mar 23 2010
Time : 16:40:32
Host :
PID :
Case : /home/peter/OpenFOAM/peter-1.5-dev/run/dieselEngineFoamValve
nProcs : 1
Create engine time
Create mesh
Selecting engineTopoChangerMesh verticalValves
keyword liftProfileFile is undefined in dictionary "/home/peter/OpenFOAM/peter-1.5-dev/run/dieselEngineFoamValve/constant/engineGeometry::verticalValves::valve"
file: /home/peter/OpenFOAM/peter-1.5-dev/run/dieselEngineFoamValve/constant/engineGeometry::verticalValves::valve from line 69 to line 107.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 213.
FOAM exiting
Peter_600 is offline   Reply With Quote
Old   March 24, 2010, 03:55
Does anyone of you know how to define the liftProfileFile or liftProfile entry in the engineGeometry dict?
I appreciate any help!
regards
Old   March 24, 2010, 06:50
Problem solved!
Just create in the engineGeometry file a link to a file with the lift profile.
liftProfileFile "liftprofile.dat"
Create the file liftprofile.dat in the constant folder with the entry:
(0 0.0001)
(1 0.0002)
regards
Old   January 14, 2011, 09:04
abminternet is on a distinguished road
Hey Pete,
I found my problem with my test case, I think the liftProfileFile is not being read right. Could you maybe post a sample of yours? I need the correct syntax, should there be an empty line at the end, or that doesn't matter? I get liftProfileStart_=0, and also liftProfileEnd=0, so doing
while (adjustedTheta < liftProfileStart_)
adjustedTheta += liftProfileEnd_ - liftProfileStart_;
in Foam::engineValve::adjustCrankAngle, it cycles!!
Any hints?
Best regards,
abm
abminternet is offline   Reply With Quote
Old   January 14, 2011, 15:54
A lift profile can look like this
0 0
5 0
30 0.003
50 0
70 0
left column: CAD
right column: lift in m
regards
Peter
Old   January 18, 2011, 05:24
great, found my error, I thought it was a set of parenthesis per point, thanks mate
Old   January 18, 2011, 14:09
Great. Happy that I could help you.
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
How I can setup Fluent for a Define_Profile on FZ? Nuno FLUENT 5 February 23, 2012 04:39
2D setup and 2D profile data file in CFX10 Se-Hee CFX 3 October 30, 2006 10:49
global panel and macro / environment setup guang ai Siemens 10 August 15, 2006 02:13
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 09:27
