Calculating pressure coefficient in OpenFoam
Like Tree24Likes
Old   August 19, 2013, 13:14
faraz
faraz22 is on a distinguished road
thanks for the reply s.m, yes this is the case in compressible flows and that is really true but usually how i calculate Cp value is just from VTK files in paraView and make a slice at particular span of blade , using spread sheet , just divide all the pressure values which you get in spread sheet with maximum +ve pressure value among all the values and here is Cp.(stagnation pressure technique). it also works. in some papers i found that some authors also do like this.
faraz22 is offline   Reply With Quote
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
How to get the time- space-average of Pressure Coefficient in FLUENT? ivanbuz FLUENT 1 August 9, 2009 15:35
Pressure Coefficient Viscous Coefficient gunposer FLUENT 0 June 15, 2009 08:10
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
