March 21, 2023, 04:53 |
Hydrogen Combustion
#21 |
Héloïse Magliano
Rep Power: 3 |
Hi everyone, I have a problem with the following case :
I try to simulate a rotational detonation combustor with hydrogen combustion. I'm using the ddtFoam solver from OpenFoam. The computational domain is an annular cylinder surface which i have created with blockMesh and the checkMesh indicates that everything is okay. I want to inject uniformly stoichiometric H2–air at 293 K at the inlet. I have part of my domains also that have specific settings of chemicals, pressure and temperture. The result of my setFieldsDict is the image below: setfields.png The ignition zone is set with the mixture at high temperature and pressure in order to auto-ignate. Deflagration is modeled through a reaction progress variable c for each cell (with c 0 representing an unburnt particle and c 1 representing a burnt particle). At the inlet the pressure should be 1bar and temperature 293K. My courant number is set to be 0.3 max. My simulations are crashing but i don't know why: my courant number is increasing and so DeltaT is decreasing to compensate. Here is the error message i get : Acoustic Courant Number mean: 9.22991e-05 max: 0.300978 deltaT = 3.65653e-10 Time = 0.00000962374, time step = 275 Quenching 9.57776e-07 % of the turbulent reaction Calculating Riemann fluxes, second order = true diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for Ux, Initial residual = 0.00726394, Final residual = 3.66489e-12, No Iterations 1 DICPCG: Solving for Uy, Initial residual = 0.00455063, Final residual = 2.40089e-12, No Iterations 1 DICPCG: Solving for Uz, Initial residual = 0.00314578, Final residual = 1.56327e-12, No Iterations 1 DICPCG: Solving for fH, Initial residual = 4.19317e-05, Final residual = 1.14321e-11, No Iterations 1 diagonal: Solving for tauHI, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for tauLO, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for c, Initial residual = 3.79914e-05, Final residual = 9.35827e-14, No Iterations 1 Combustion progress = 99.13% diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoEu, Initial residual = 0, Final residual = 0, No Iterations 0 [7] [7] [7] --> FOAM FATAL ERROR: [7] Maximum number of iterations exceeded Test = 11198.4 K, eu_ = 1.20943e+07 J/kg, e(Test,fH) = 1.06602e+07 J/kg [7] [7] From function eUnburnedThermo::correct(const volScalarField& fH) [7] in file eUnburnedThermo/eUnburnedThermo.C at line 413. [7] FOAM parallel run aborting [7] [7] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [7] #1 Foam::error::abort() at ??:? [7] #2 Foam::eUnburnedThermo::correct() at ??:? [7] #3 [7] at ??:? [7] #4 __libc_start_main in "/lib64/libc.so.6" [7] #5 [7] at ??:? -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 7 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. My files are attached to this post. If someone know what my problem could be please ? (maybe with my pressure BC ?) 0.zip system.zip constant.zip |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 13:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 08:21 |
Problems with boundary conditions for a lowRekOmegaSST turbulence model | cfdmarkus | OpenFOAM Running, Solving & CFD | 16 | November 14, 2011 05:44 |
Pressure boundary conditions | Lionel S. | Main CFD Forum | 1 | August 24, 2007 19:03 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
